I've seen something like this in another forum, the guy had a problem with his HDMI connection. If he used DVI or VGA with the 3.5mm sound cable it all worked fine, but when it came to HDMI, he had problems with audio and video. Check to see if the cable works with other hardware and if it works fine, it might be that your monitor's HDMI port was simply DOA from the start.
