So this is my first build and I have done some research on building computers. I am not sure if all the components i picked out are compatible. This is what I have so far:
Motherboard and CPU $112.98 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.190816
HDD: $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
RAM: $47.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Power Supply and Case : $84.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.190683
DVD Drive: $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Total Cost including Shipping: $351.48
This is not for gaming and it is a budget system for my parents who just browse the web. Not sure if i need a graphics card or sound card since they are already on the mobo. I don't need HD sound just regular sound and graphics. If you guys could give some advice on how to make this build any better or cheaper without low performance it would be appreciated. Will I be able to use broadband with all these parts(wired).
I already have a monitor, mouse, and keyboard. I think I will buy windows xp or vista(if xp available then that).
Also on the mobo what does this mean for sound and how will i fix it during the build:
2/4/5.1/7.1-channel (Note)
Note: To configure 7.1-channel audio, you need connect with the port of HD Audio standard via front panel and enable the multi-channel audio feature through the audio driver. Budget around 400$
Thanks
HDD: $69.99
RAM: $47.99
DVD Drive: $24.99
Thanks
