Tom's Hardware > Forum > CPU & Components > CPUs > Please help, can't get geforce 7050m-m v2 to work
Forum CPU & Components : CPUs - Please help, can't get geforce 7050m-m v2 to work
Hello, this is my first post here, so bear with me for I am a newb to these forums :)
well I finally upgraded and bought a bundled geforce 7050m-m v2.0 with 7750 amd phenom x2+
other specs are cooler max 460 watt ps
maxtor 40g IDE Hd
1 gb super talent ddr2 800 ram
windows xp sp2
please help, it boots to the bios screen, but right after that I get the windows "we apologize" windows did not start successfully then can choose safe mode, safe mode w networking, safe mode w command, last known good config, or start windows normally.
Iv tried all options then I get a really, really fast blue screen that I can't read then it reboots.
Please help I don't know what to do at this point, is it my hard drive?
Thanks any help is much appreciated
-Tyler
Sponsored Links
Did you do a format and fresh install of windows? Most versions of windows require this when changing motherboards. You might be able to backup files if you use your old board before installing the new one.
Reply to o1die
Go to Start -> Control Panel -> System
Go to Advanced
Under the Startup and Recovery section, click Settings...
Under System Failure un-check "Automatically restart"
Blue Screen of Death Survival Guide: Every Error Explained
http://www.maximumpc.com/article/f [...] ival_guide
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Try doing a Windows repair, if you changed hardware.
Try loading a Linux LiveCD to see if it's a Windows problem.
Reply to evongugg
There are 1146 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
