Solved
Is this power supply enough for this video card?
this is the power supply (Corsair VX550W 550W ATX 12V 41A 24PIN): http://ncix.com/products/?sku=25984&vpn=CMPSU-550VX&manufacture=Corsair
this is the video card (MSI N260GTX-T2D896-OCv3 GeForce GTX 260 896MB) : http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127426
If you need more info:
There is 1 hard drive, 1 cd drive and an AMD Phenom II X3 720 Black Edition Triple Core Processor AM3 2.8GHZ, 4 gb ram
3 answers Last reply Best Answer
More about power supply video card
  1. It is enough for that.
  2. A 500W is sufficient, so no problem.
  3. Best answer
    Plenty. It has a 41 amp 12 volt output.
    GTX260 needs about 11 amps and even your CPU is going to pull less than 10 amps even if you overclock. Leaves plenty in reserve.
Power Supplies Graphics Cards Components
