I am currently running a 3.5 year old system that has had minor upgrades over its lifetime.
The only hardware that I am carrying over from my old system is my pair of 8800GT's and my Razer Barracuda sound card.
I was also recently given a WD Velociraptor drive 150GB and I have a few spare DVD drives hanging around.
I have read the numerous comparisons between i7 and PII and my head hurts.
I am a gamer. I play MMOs and a few FPS's on a 24" LCD. I prefer to run everything at native resolution. I like eye candy as much as the next guy so I turn up the effects as far as they will go and remain at a playable frame rate.
I am familiar enough to feel comfortable overclocking but won't feel I am missing life if I run stock.
Win 7 is my planned OS.
My budget is ideally $800 but I can stretch that a little if needed.
So what I need to figure out is do I go with a new Intel or AMD system?
The entire purchase will include CPU, Motherboard, Case, CPU cooling, Power Supply, Memory.
Can anyone give me good reason to select one chip manufacturer over the other?
If you want to carry over those 8800 GT's in SLI then you should probably consider I7 - that kind of case and PSU do you have - could you potentially carry that over?
That gives you a bit for cooling - best bang for buck there is the Xigmatek 1283 and a few others - shouldn't spend more than $50 unless you plan on some extreme overclocking (very little gain)- because it is not necessary.
I am running a 500w PSU now that I might be able to reuse, but I am worried that later I will have issues. I am recycling the 8800s (and yes continued use of SLI was my intention) with the intention of upgrading to DX11 cards later.
I may even be able to save the case, but I am thinking I can slap my old 7600GTs back into this existing system, use on board sound and have a decent gaming rig for my son to play on. He is only 6 so by decent I mean low end but playable.
500W should be enough if it's a high-quality PSU. You will be fine with both. I think the build nerrawg proposed is perfectly suiting you. Plus, get bonuses by overclocking your i7... they overclock like mad!
I think it's a good one, since you have quad-cf/3sli with it, so you can basically upgrade later to an ATI card and still get the support for 4 of them...
Ok, I am a little paranoid about the power I guess, but the price difference for the 750w was minimal so I upped to that one. I also would like try my hand at overclocking so I tossed in what I think is a decent CPU cooler.
Here is the build I am considering, comments and suggestions welcome.
Add to that the pair of 8800GTs, the Razer sound card, the Velociraptor 150GB drive and the LG Bluray DVD that I have on hand and I am getting excited about this machine.
8800GT's in SLI aren't that powerful, infact they're barely powerful enough to warrant having them in an i7 PC.
I agree they aren't that powerful compared to what is available, but they are hardly junk.
Consider that the 8800 is essentially a 9800 and that is essentially a 250.
Moving from an Athlon X2 with 2GB of DDR1 to an I7 system is much more of an improvement than moving up form the 8800GT's to any other card within my budget. I am really hoping to see some new 40nm cards from ATI by the end of the year. Now that would justify an upgrade for sure! AND, the board I am looking at here can handle quad crossfire, so that would certainly be an easy option later on.
Switch out the Antec 300 case with the Cooler Master 690 Case. The CM 690 case is the best case for the price, IMO. It provides great cooling and has plenty of space.
Reviewed the case options and decided to take the CM 690.
Seems like it has a bit more space than the Antec 300 from what reviewers had to say. Thanks for the suggestion.
Case was just delivered.
OMG this thing is incredible. Plenty of room, fan placement is best I have ever seen, easy installation for everything (or so it seems) built in cable management...CM690 is the case to have.
Thanks for the awesome tip on this case!
Rest of the parts are set to be delivered tomorrow, will update when I have it all assembled.
Message edited by cimtaurus on 05-27-2009 at 09:03:06 PM
Well, I am submitting this reply from my new system. Assembly went very smooth. I have the i7 overclocked to 3.3 and the temp is sitting at 65C. (running prime 95)
Running windows 7 64bit ultimate and I have to say this is a pretty snazzy OS.
Installing some games now, but I can already tell you this mchine rocks.
Thanks for the advice, and for those considering a new system I would say that the i7 is the way to go.
I believe your system is good =)
Although I'm currently building a x3 720 system... well, it's just that I can't afford anything more I think you can push you i7 a bit more, especially since your not on stock cooling, just let the thermal grease install itself correctly (about 48 hours of running) and you'll see your temps drop again.
