I bought a q9550 and the core temp's differ by about 5 degrees and more when just running normal programs like ocz. Is this normal?
I am using the stock cooler, what is the max fan speed? mine reaches +-2000rpm at max revs.
And when 100% under load it gets up to 70-80 degrees C. thats too hot right?
I have orderd a Coolermaster Centurion CM590 (CM-RC590K)case. Will this make a big diference with this temperature problem? curently using a small case
