Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] Q9550 Overclocking,tempature, problems.
Forum CPU & Components : CPUs - [Solved] Q9550 Overclocking,tempature, problems.
Best answer from MRFS.
Hello Everyone, first time poster here, and im a first time builder.
So i had a lot of problems then the average user when buying parts, for example being sent the wrong psu then rmaing that.
Case had a dent, rma that. Got a bad motherboard,dieing on me 2 weeks into, rma that, and so now, I'm at the 26th day of the 30th that newegg would be cool with me.
with their warranty, i have all my parts together and i re-put in my build once more. I now get to enjoy it, well somewhat need to finish
homework and school starts in 3 days.
Anyways, My I still have a couple dilemma I'd like to ask people.
So when i put it back on and start it up the 1st time, i got an error saying cpu over tempature press f1 to resume. So I googled the error and the solution was to replace the heatsink and to make sure the hsf is pushed in all the way
Well I knew that it was for sure this problem since i broke both of these symptoms.
Since i had to take out everything and stick it back on, the cpu heatsink was all rubbed off and everything.
The intel stock fan that came with it, 2 of the pin's wont push in, yes i've tried from every direction/angle, only 2 of the 4 will go in. I assume it might have been messed up when i took them off since i had to rma that mobo.
So now my rig is runnin at this; Which is extremely high at idle! I understand the factors of a bad thermal compound that's been really smeared off sine
the first time i had to take off and put it back on, but are these tempatures really reasonable? I mean i google up with peoples temp
being idle at like 30 degress celcius and mine's hittin 70 at start up.
http://i82.photobucket.com/albums/ [...] emppic.png
Sry if you can't see it, it says Tj Max 100C
Core 0 73C, Core 1 68C, Core 2 68, Core 3 70.
I ordered artic silver 5 and a zalman cnps9500 to replace both of those along with a 120mm side panel fan for gpu,articlean and another connector.
The question to that will bring me up to my next current question.
So im running a Q9550, And i would like to overclock, (of course after i get the new fan in). I was thinking of going up to 3.5, so while, booting up i went into the bios screen and I'm lookin around and there's like no way i can change the multiplyer or the fsb.
I'm usin a ASUS P5Q SE PLUS motherboard also. So i guess the question here is, where do i go to, so i can edit all these and
begin overclocking?
http://i82.photobucket.com/albums/ [...] G_9433.jpg
Please and Thanks Community!
In the BIOS, set "Ai Overclock Tuner" to MANUAL.
I checked your motherboard User Manual, and
your "System Bus" can run at 1600 MHz
(raw "Bus Speed" of 400 MHz quad-pumped).
Then, at "FSB Frequency" enter your raw FSB clock rate e.g. 400.
See Page 2-17 in your motherboard User Manual,
for further details.
You might also want to enable SpeedStep,
so your machine will automatically increase
the FSB multiplier when the CPU is busy.
MRFS
Sponsored Links
Hello, I just went through some of the same things you did with my q9550 rig. I can possibly offer assistance with your CPU issues. (I have built a few systems in the past and this is my first experience with the newer stuff) Reguardless the thermal paste issue is a big one for temps. I used artic silver5 on mine with a coolermaster V8 and i have temps running between 35 to 40 for the CPU. My first issue however was the program that I was using to report temps was giving inaccurate readings. Try running Real Temp and CUPID. I couldn't really tell what program you had running on yours with that pic. My system monitor that came wtih the mobo was giving me temps around 60-65 so it was off. If your getting messages from the bios however, it seems like you may be having heat transfer issues to the heatsink.
Reply to jx02123
After my first run in with turning on the computer, the message stopped popping up, but im still getting high readings. I have cpuid on my computer, but wow i didn't know that could tell you temps, which i guess brings me to ask where i can look that up in cpuid.
In the picture I used Core Temp to get my temperature readings.
Reply to Leafy
http://www.cpuid.com/hwmonitorpro.php that will show you temps and all of your voltages and such. Nifty tool. And i thought for a min... You only have 2 of the 4 pins holding on your heatsink? If thats the case make sure all of the little slits are lined up the correct way (on the black tabs the removal things) I only mention this because My first time assembling this system i had one that wasn't when i first applied the stock fan.
Reply to jx02123
Read and heed:
http://www.supremelaw.org/systems/ [...] arning.htm
There is a very cost-effective solution here:
http://www.sidewindercomputers.com/lgbowiscsp.html
We're running a brand new Q9550 with SpeedStep
enabled and an FSB=400MHz x 8.5 = ~3.4GHz,
and the CPU temps are hovering around 100 F.
It's the stupid push-pins!!
MRFS
Reply to MRFS
Well here i went ahead and just used realtemp.
http://i82.photobucket.com/albums/ [...] G_9434.jpg
Reply to Leafy
MRFS wrote :
Read and heed:
MRFS
Thanks for that, I've already ordered the zalman fan though.
Now i just need to worry about my overclocking/bios issue.
Here are some more pictures i just took to help out.
http://i82.photobucket.com/albums/ [...] G_9435.jpg
http://i82.photobucket.com/albums/ [...] G_9436.jpg
http://i82.photobucket.com/albums/ [...] G_9437.jpg
http://i82.photobucket.com/albums/ [...] G_9438.jpg
http://i82.photobucket.com/albums/ [...] G_9439.jpg
http://i82.photobucket.com/albums/ [...] G_9440.jpg
Reply to Leafy
Best answer
MRFS
Reply to MRFS
Here, set "Ai Overclock Tuner" to MANUAL.
Then, change the "FSB Frequency".
RTFM (Read The "Fine" Manual :)
MRFS
Reply to MRFS
MRFS
so that's what i had to change? Oooh, i was like looking around at images and videos and other people just simply went into their bios and moved around their multiplier. I will try this, Yeah i didn't look at the manual, then again i wonder where i put it, most likely in the garage with the rest of the boxes, thanks for your help tho MRFS
Reply to Leafy
The Manual is on the Support CD in .pdf format:
it's also at the ASUS website for that motherboard
in .zip compressed format:
http://usa.asus.com/search.aspx?se [...] 5Q+SE+PLUS
Then go to "Download' and you'll see "Manual" in the
list of possible "downloads" for that motherboard.
MRFS
Reply to MRFS
MRFS
I was reading around and most people say to turn it off, so that it'll just stay oc'd all the time for more stability and to i don't have to wait to start doin somethin for it to turn on.
Reply to Leafy
MRFS
Was in bios, so i turned ai overclock tuner to manual. Then i assumed when u say fsb frequency u talked about fsb strap to north bridge, it turns to 333 when it goes manual but i can't seem to change it anymore if it's manual.
Reply to Leafy
There are 971 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
