Tom's Hardware > Forum > Homebuilt Systems > New System Build > Newly built computer does not boot....fans work, and lights....
Forum Homebuilt Systems : New System Build - Newly built computer does not boot....fans work, and lights....
Hello,
I have a newly built computer with an Intel Extreme QX 9650 CPU, Invidia Quadro FX 1700 Video card, AsRock P45R2000-WiFi Mobo, OCZ 600 watt PSU,2 X 2GB Ballistix DDR2 800 RAM(Very low latency).....
NO error messages from speaker....all fans work ok.....computer does not go to BIOS and monitor does not seem to receive signal. HAve re-chacked all wire hook-ups etc.
Could it be incapatible RAM??? or CPU???
Please help,
Sponsored Links
Why a QX9650? I hope you didn't buy it new...
Anyways, it could be several different things. The culprits are most likely: 1. Motherboard 2. Ram 3. PSU. You said there are no error codes from the speaker...that is a case speaker right? I ask because a regular computer speaker system will not play error codes from the motherboard.
If you have the case speaker hooked up, then I would say its your motherboard most likely, since your PSU is supplying some power to the system. Otherwise you would be getting error codes.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
^True that.
1. Do you have the 4pin CPU plugged in?
2. The board isn't well known. And generally boards that support DDR2 + DDR3 have issues. Also, I don't trust AsRock quality.
3. The Crucial Balistix are known to have issues (memtest86+ failures,etc) also. Used to be good RAM a few years a go, but now their quality is a problem.
@OP: What's this PC used for?
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Case speaker is hooked up....
1.) 8 pin and it is plugged in...
PC is used for rendering and editing video
Reply to leaping-lemur
Shadow703793 wrote :
^True that.
Board's dead, if it would be the RAM, you'd hear 2 beeps from the speaker.
Reply to Shnur
When I took out the RAM there was an error message....are you sure the board is dead??? It was bought brand new.....
When I take out the RAM there is 2 beeps from the speaker....are you sure the board is dead....it was bought brand new....
Ok, then PSU has some troubles, do you have a second PSU to check with?
Reply to Shnur
No second PSU....everything seems to have power...what do you mean by "issues"??? compatibility?
I have another PSU but is very low wattage...won't power video card... what troubles? compatibility?
Low wattage = ?
Issues; maybe a bad PSU (happens to new stuff sometimes, they're just, bad).
You'll need at least 260W.
Plug your components into this PS Calculator to see if you'll work, I didn't found your FX1700 card, so I've put a FX2000 instead.
http://www.extreme.outervision.com/PSUEngine
Reply to Shnur
OK have another PSU to try.....I will let you know if I have any luck...thank you...
Try one stick of RAM instead of both. Make sure its in the right slot(s) according to your mobo manual.
Reply to nickhoff
OK so it has been solved.....After trying alot of your suggestions I found an old friend that works at a computer shop....one of the technicians took a quick look at it....
He tried 1066 RAM instead of the 800 RAM that was installed.... Everything worked...
Even though it says DDR2 800 RAM was compatible it actually was not with this configuration...
Thank you for all that helped..... now I just need to find someone to buy the 4gb of Crucial Ballistix (4-4-4-12) DDR2 800 RAM, so I can get some Mushkin low-latency 1066 RAM from the store who helped me.....
Thank you all again.....!!!
Yeah crucial ram is pretty suspect these days. They require very high voltage which can cause problems for a lot of people when doing a fresh build.
GTX 260 Core 216
Reply to xthekidx
There are 1215 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
