Tom's Hardware > Forum > Graphic & Displays > Nvidia > Asus Geforce GTS250 Dark Knight 1Gb BIOS. Mine doesn't power save?
Forum Graphic & Displays : Nvidia - Asus Geforce GTS250 Dark Knight 1Gb BIOS. Mine doesn't power save?
Hi there
According to this Tomshardware article: http://www.tomshardware.co.uk/gefo [...] 573-4.html
...the Asus card should power save considerably in 2D mode.
Based on this article I went out and bought this card. Now I have it theres 2 things wrong.
1) The clock speed of the memory is actually clocked at 2000Mhz DDR and not 2200Mhz
2) The clock speed in 2D mode does NOT drop down to the levels they experienced in this review. In fact it does not drop down at all?
Has anyone else experienced this. Also if you have this card and your card is clocked to 2200Mhz DDR speed could you please, please save the BIOS so I can try flashing it to my card?
Theres 2 possibilities here.
1) Tomshardware was given a special card which didn't get sold in the shops to make it look better than it actually is.
2) My card doesn't have the BIOS it should have.
My BIOS is as follows:-
http://homepage.ntlworld.com/stonedofmoo/CPU/GPU-z.jpg
Can anyone help and give me some suggestions?
Chris
Sponsored Links
The curious thing is that yours is made with the old 65nm process, and from what i knew all GTS 250 are made using the 55nm TSMC process. But anyways, have your installed ASUS's utilities for the GPU? It might need it afer you installed the latest driver to proper throttle itself.
Reply to SpadeM
Hi there
It is a 55nm chip, but for some reason GPU-Z doesn't appear to differentiate between the 2. I've not installed the Asus utilities, only the Asus drivers which appear to be direct copies of the Nvidia drivers anyhow.
Do you need the Asus utilities? In my experience those utilities never seem to like x64 OS's. Also that wouldn't explain the slower memory clockspeed of 2000Mhz when it's listed as 2200Mhz on various sources and reviews.
Reply to Stonedofmoo
Check your retail box and if it says 2200 mhz on the outside features, maybe you can return it since the packaging doesn't match the contents.
I have the XFX GTS 250 512 mb. GPU-Z hasn't been updated to show that it is 55nm fab.
I had an old 8800 GTS 512 that could overclock the gpu core all the way to 800 mhz. Sadly, my GTS 250 will overclock only to 790 mhz... not much room to increase the "stock" setting.
Reply to HundredIslandsBoy
I emailed Asus support on the same day I got it to ask them about the lower clock speed and lack of 2D power saving, and they simply closed the case without bothering to answer. I wasn't impressed.
Sounds like you're 8800GTS was an amazing overclocker HIB!
Do you have Aero enabled?, if so turn it off.
Reply to mousemonkey
Hmm, I do actually. Does that count as 3D mode then?
The Tomshardware review didn't mention anything about turning that off, but I will certainly try that later when I get home.
Yes, that's why it look pretty. ;)
I'm using Windows 7 btw, would this have the same issue?
I'll try your tip tonight and let you know the result :)
Go to 'personalize desktop' > 'Themes' and put it into 'Windows classic' which should be 2D (I'm not running W7 at the moment).
Hi there. I tried the Windows Classic mode, unfortunately it has not made any difference. The clocks are still 740/1000
Maybe you can't turn Aero off in W7, hopefully someone can confirm or deny.
- 0 +
Hi Stonedofmoo,
I have the same card as you and the GPU-Z screenshot you have shown has the same results as mine. Mine doesn't go into a power saving mode either, although the fan speed does vary according to the chip temperature (35% speed at low temps).
Somewhat bizarrely though the fan speed stays at 60% after starting Windows until I run a 3D app. When I run FurMark for example, the fan slows down to about 35% speed and then slowly increases with the increased temp. When I exit FurMark the fan speed drops back down to 35% and stays there (until I stress the GPU again) which is how it should be without me having to mess around like this.
BTW, I'm running mine on a old ASRock Dual-SATA2 mobo with a 3800+ x2 CPU and Windows XP Pro. I'm actually very pleased with the card but would like to sort out the fan glitch (I've tried the 182.08 and 182.85 drivers)
On the ASUS website it does say that the memory on the 1GB model runs at 2000MHz. I knew about this when I bought it.
Anyway, I hope we can get to the bottom of this discrepancy regarding the power saving mode.
Bye, kremmen
Reply to kremmen
Hmm thanks for the reply, this is interesting because I was hoping the issue was because I was running Windows 7, but you're running XP and have seen the same issue.
I'd like to get Asus to comment on this because it seems off that Tomshardware got a card that power saves, and based on that review I went out and bought their card. Now I have it, mine does not do the same.
Btw Kremmen, what bios does your card have?
- 0 +
Hi Stonedofmoo,
My BIOS is exactly the same as yours, 62.92.7D.00.11 (according to GPU-Z 0.3.4). I'm just wondering if ASUS had issues with the powersaving mode and decided against it in the long term. I say this because I've recently read of users of EVGA GTS 250s having all sorts of problems due to the shifting power requirements of their cards when changing from 2D to 3D and back. Lockups seemed to be the main problem.
Anyway, I think I'll get in touch with ASUS and find out what's going on.
Bye, kremmen :)
Reply to kremmen
ok great. I hope you get more of a reply than I did, they simply closed my case without saying a word!
Did you get any reply Kremmen?
- 0 +
Stonedofmoo,
I have the same card, same bios info (from GPU-Z) and am running win7 x64. Same behavior, the clock runs at full speed - regardless if i'm running a directx game or not.
I don't have any info on what the correct behavior should be, but thought you might like to know what i did about it. Using rivatuner, i set it up to underclock the card on windows start up, and resume. Before running a game, i have a profile to ramp back up (or overclock).
There are also some good fan controls with riva tuner as well. Using 'low-level fan control', you can even bring fan speed down below 35%. I have it default low setting at 25% (slowest setting for which i can't hear the fan). Hope you find this some help
Useful Rivatuner links:
http://www.guru3d.com/index.php?page=rivatuner
http://rivatuner.doomdealer.com/
Reply to mfrasca
Hi there
I've gained some extra information since starting this thread. Basically using the new NiBiTor 5.1 I have confirmed my ASUS GTS250 BIOS DOES have a low power 2D mode set, the issue is it's never getting a chance to use it.
http://homepage.ntlworld.com/stonedofmoo/CPU/Nibitor.jpg
I'm wondering if it's a x64 bit issue as the review machine was using Vista x86 and everywhere I search on the net it either says it's a multi monitor issue (but I've tried single monitor), or the posts mention they're using Windows x64.
The only way to test this will be to drop back to Windows x86 and see what happens. I might do this shortly when Windows 7 RTM is released to try it before doing a proper install.
Incidentally the rivatune idea is a good one, but it doesn't support the latest drivers and also although it declocks the cards, it does not reduce the voltages like the BIOS would do, this is where your real power savings come in. I'll update this post with anything else I find.
http://homepage.ntlworld.com/stonedofmoo/CPU/NibitorVoltage.jpg
There are 1193 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
