Sign-in / Sign-up
1100T Stock vs Arctic Cooling Freezer 64 Pro
  • AMD
  • Cooling
  • Arctic
  • Phenom
  • Overclocking
  • Product
March 30, 2011 2:47:49 PM
Hi there folks,
today i ordered a Phenom II X6 1100T and i was wondering what would provide better cooling
-the stock cooler that comes in the boxed version
or
-the Arctic Cooling Freezer 64 Pro ( that i used with my old CPU, a x2 6400 )
i appreciate any kind information
More about : 1100t stock arctic cooling freezer pro
a c 311 K Overclocking
a b À AMD
March 30, 2011 2:57:53 PM
Hi and welcome to Tom's forum.
The stock cooler that comes with the CPU is good, but the freezer can give you a little better temps.
But if you want overclock and very good temps, you will need a better cooler.
a b K Overclocking
March 30, 2011 3:19:10 PM
Yes the Arctic cooler freezer pro 64 will provide better cooling than the stock heatsink but not a whole bunch.
If your planning to O.C. i suggest you get something like a Hyper 212+ or the Xigmatek SD128264 Aegir.The Aegir performs extremely well but the Hyper 212+ can perform well just more at a budget level.
March 30, 2011 3:55:52 PM
Well i expected no better of that old cooler
thanks for your advice, i will take a look at those coolers :)
