The board I have supports both SLI and Crossfire, so a second card upgrade later would be possible with either choice. My intention is to upgrade again with a second card by the end of the year.
I don't have a preference between nVidia or ATI, I just want to know which of these two cards is going to be the best choice based on the following:
- Performance
- Upgrade scalability (SLI/Crossfire)
- Gaming Support (Drivers)
Keep in mind I am not asking which chip manufacturer makes the better card, I am only interested in the comparison of these two cards OR any similarly priced card with compatible performance and support.
Hmm...So assuming you play 1920x1200 I would recommend personally getting a single GPU as it is more reliable and stable. For that resolution and based on your games I think a GTX275 would do that job
