Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Can two gtx 260's run in sli with a 700w power supply
I have a 700w power supply http://www.newegg.com/Product/Prod [...] 6817814015 and i want to run two gtx 260's in sli. is that possible with only 700w and would it be a problem using the molex to pci-e adapters on one of the cards?
Sponsored Links
If your PSU is any good it shouldn't be a problem. Generally, even with an i7 a system with two 260s in SLI should use a bit less than 500W. I don't know who really makes that PSU, and I don't feel like researching it, but as long as it's done decently by someone like FSP it should be O.k.. Google it to see if you can find any reviews of the thing and more info.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
- 0 +
yes that powersupply would be able to handle it, its a rare powersupply but it has got great reviews every single time i have the 1100watt version. which is even rarer.
ABS/TAGAN is a german company, they don't themselfs make powersupply units they have a sub comany that makes them to thier specs and design.
Message edited by AMG on 06-11-2009 at 08:20:28 PM
------------------------------ Q9550 3.8Ghz//ramapge formular//OCZ reaper 4Gb// 3 seagate HDDs// sapphire HD4870 512 // CM HAF 932
Reply to AMG
So, you already have the power supply? Maybe you should just hook it up and find out instead of trying to guess?
The New Number Two
Reply to thenewnumber2
- 0 +
i said I have it and its happliery runinig my system, I ve had no problems with it. yet I was orginally going to get the 800watt which is very simplier to the 700watt. however OCuk gave me this one instead. well not gave obvosuly
Message edited by AMG on 06-11-2009 at 08:47:31 PM
Reply to AMG
i already have 1 gtx 260 i just wanted to know that if i got another one it would work. especially with the molex adapter
Reply to greentea5425
It's a close call, but it *should* be OK. My SLI system pulls about 625-650 W under load, but I have 8800Ultra's. Yours will use a bit less, I think. Go for it.
The New Number Two
There are 1289 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
