HELP!! CPU temp spikes
Biostar TA790GX A2+ MOBO
Apevia 550W PSU
AMD FX-62 CPU
OCZ Platinum Series 2GB 800Mhz
Visiontek Radeon X850 GPU
WD 250 GB
Windows XP Pro 32bit
Hello Everyone,
When I ran Speed Fan to measure my CPU temp it read 93C. So I swapped the CPU into my dad's mobo and it was stable at 51C for an hour. When I put it back into my computer it would read 51C and every few seconds it would jump to 93C and go back to 51C. I built this a year and a half ago.
Any help would be appreciated.
4 answers Last reply
More about help temp spikes
  1. Do you notice your processor usage go up correspondingly in the task bar? otherwise, it's probably a software bug with Speed Fan.
  2. Nope, Theres no mass CPU usage when it spikes to 93C. I also used to other programs to measure the temp and it does the same thing.
  3. I assume you did the clean, apply new thermal paste and reseat the heatsink in the transfer?
    If that is all fine then reboot and go into the bios and
    I suggest you also update the bios.
    http://www.biostar-usa.com/app/en-us/t-series/introduction.php?S_ID=374
    The FX62 is also not listed ... a bit odd as the 6000+ and 6400+ are:
    The the mobo book states: Socket AM2+
    AMD Athlon 64 / Athlon 64 FX / Athlon 64 X2
    / Sempron / Phenom processors
    http://www.biostar-usa.com/app/en-us/t-series/cpu_support.php?S_ID=374
    Install Hardware Monitor
    HW Monitor is a monitor utility that helps you to maintain the health of the PC.
    It provides real-time information of CPU/GPU/System temperature, fan speed,
    and voltage
    Try their tech support below:
    eHot-Line (Optional)
    eHot-Line is a convenient utility that helps you to contact with our
    Tech-Support system. This utility will collect the system information which is
    useful for analyzing the problem you may have encountered, and then send
    these information to our tech-support department to help you fix the problem.
    Before you use this utility, please set Outlook Express as your default e-mail client application program.
    Hope this helps.
    A bios update is a good start.
  4. I have tried updating the latest bios and still get the same problem. I also remounted the heatsink and fan. I will go ahead and try the e-hotline when I get home. Thanks!
CPUs
