I've been having some problems with my Intel E8400 Dual Core Processor's Temperatures., using a CoolerMaster Hyper TX 2 Processor cooler my resting temperature is around 50 and under load I've seen it go as high as 90-95C (recorded using RealTemp)
I thought it could be my application of Thermal paste that might be causing it, but I've already cleaned and reapplied that, so I don't think that's true.
Does anyone have any ideas what might be causing it?
Is that Fan enough to cool it properly? My Fan's RPM is 1800 or so: Is this high enough for the TX2? Or is it simply that I've got a duff part somewhere?
------------------------------E8500 oc'd 4.5 @ 1.44 vcore with 92mm Zalman
ATI 4850 oc'd 680/1158 with aftermarket Zalman
Asus P5Q Pro mobo
2 gigs 800 Corsair ram @ 4-4-4-12
Reply to werxen
If, by push pins, you mean the pins that connect the Heatsink to the Motherboard, I'm pretty sure that they are correct, is there any surefire way of checking they're not?
Already done my friend, but thanks for the tip all the same!
Take out your motherboard and look at the underside make sure the plastic pins are through the holes. That's the only way to be sure.
Also, have you checked to make sure you are getting a solid contact between the CPU and heat sink bottom? The best way is to look how your paste is spread. Sometimes there are manufacturing flaws that allow concave or convex gaps between the two surfaces.
------------------------------E8400->4.4GHz || Zalman 9700LED || ASUS P5Q Pro || 4GB G.SKILL PC8500 || EVGA GTX 275 896MB -> 697/1266/1590) || Sound Blaster X-Fi Fatal1ty Pro || WD Velociraptor 150GB + Caviar Black 640GB || Pioneer, Samsung DVD-R/Ws || Antec 900
Reply to 10tacle
