Hello,
I have a 120mm PWM fan installed on my CPU heatsink. Motherboard has a slot for a 2nd PWM fan... what would be the best use for it? I have an Antec 300 case, so options are:
1) Top 140mm fan
2) Rear 120mm fan
3) Side 120mm fan
I'm worried that putting a PWM fan on the side isn't a good spot, since that location is to cool the GPU and the PWM functions based on CPU load instead. What would be best?
1) Top 140mm fan
2) Rear 120mm fan
3) Side 120mm fan
