Power Supply - Dell XPS 420 (UK)
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply - Dell XPS 420 (UK)
Please can you help me or point me in the right direction for my help?
I am looking to buy...
Silencer 500 Dell
Mfr. PN: PPCS500D
but can't seem to find it available in the UK? I am led to believe I need this particular power supply as it is an upgrade for my Dell XPS 420 desktop system - it's a perfectly compatible upgrade for my PC.
The nearest part i can find on the UK market is
OCZ PC Power & Cooling Silencer 500W EPS12V ATX PSU (UK)
Mfr. PN: PPCS500-UK
The big question - will the 2nd power supply part be compatible with Dell XPS 420 system?
Sponsored Links
the pc power an cooling is a recommended replecement for the dells
Reply to obsidian86
- 0 +
yes but I can't for the life of me find one for sale (or decent shipping price) to the UK.
I will have a look at some dutch websites to see if i can find the Pc Power & Cooling silencer 500 dell then...
Reply to cps1974
- 0 +
Another option you have is the ANTEC EA500 or EA650...
both fit perfect on an XPS 410/420 ........
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
oooh thanks!!! am checking these now, many thanks
Reply to cps1974
jus had a look and seems most atx power supply's should fit
Reply to obsidian86
- 0 +
yea, im just lettin him know that the EA's work fine since I have an XPS 410 and a 420 and both PC's have been upgraded from the ground up, starting with the PSU's....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
right EA it is then!
I was led to believe the wiring spec of something else (I'm now clued on PSU, can you tell?) so you could pretty much be stuck with the PC Power & Cooling (OCZ?) Silencer 500 Dell
great! just an after thought OvrClkr - what kind of video card are you running in your 420? - I am a little hesitant to take the plunge on dual slot options - ideally I'd like to get Radeon HD 4770 but may consider getting HD 4850 (I've seen the latter today on ebuyer for £70 UK) if the buggers will fit :o
Reply to cps1974
- 0 +
course now i've noted your sig with pc specs - which is that - xps410, 420 or another system ?
Reply to cps1974
cps wait till ati launch the 5xxx series cards mid october the 4xxx series prices will drop
Reply to obsidian86
- 0 +
The 410 has an HD 4850 (XFX) and the 420 has a GTS 250 (BFG).... both XPS's are powered by an EA500 with power to spare......
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
wow thanks again OvrClkr and obsidian86!
Reply to cps1974
- 0 +
sorry to bother you guys again - i've been browsing all night, no gaming yet
almost done, think I'll order EA650 simply cos the price I've found is great, pretty sure I'll plump for XFX HD 4850 1GB I've found at £80
I imagine the 4850 should just fit in the XPS 420 case OK?I've got plenty of room above the card but will it fit in long ways, worried it might not fit with the large CPU cooler I've got above the quad core processor
do the 410 / 420 differ by much in terms of how much space they have for gfx card?
any chance of taking a photo of your 410 and 420 with the side off? wouldnt mind seeing if you have the same processor heat sink job as me
I am almost there but total upgrade of £140 is heck of a lot of money for me
I do appreciate all your help, cheers!! :wahoo:
Reply to cps1974
- 0 +
yea no problem.... once I get home I will take a pic and show you......
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
just thinking should i take this thread elsewhere cos it has digressed to gfx card thread?
if not, given my max settings of 1280x1024 would i be as well to stick with 4770 higher core clock, price seems to be about the same so it's 4770 vs 4850 (both XFX, the 4850 is cheaper!)
ruddy decisions!
Reply to cps1974
- 0 +
awesome, thanks!
Reply to cps1974
- 0 +
right i'm off for a quick (slow) game of COD5 with my HD 4670, yuk!
Reply to cps1974
- 0 +
hehe CoD5 is horrible.... well at least IMO.... CoD4 and L4D is the way to go....
anyways here are the pic's of the XPS 420 :
http://i683.photobucket.com/albums/vv199/OvrClkr/Picture001.jpg
http://i683.photobucket.com/albums/vv199/OvrClkr/Picture002.jpg
http://i683.photobucket.com/albums/vv199/OvrClkr/Picture003.jpg
http://i683.photobucket.com/albums/vv199/OvrClkr/Picture.jpg
Message edited by OvrClkr on 08-27-2009 at 02:14:23 AM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
[quotemsg=1973433,18,446940]hehe CoD5 is horrible.... well at least IMO.... CoD4 and L4D is the way to go....
thank you!
awesome pics, that card is looking sexy!
my problem will be the cards i have below, TV tuner card I can ditch as I now have USB stick dual digital tuner but I also have my soundcard and LAN card below where your 250 is
i suppose I can get USB wireless adapter to do away with the LAN card too
Reply to cps1974
- 0 +
well that should not be an issue, there should be at least 1mm of clearance room between all the cards.....
as far as USB wireless adapter, I would not know.... I have always used WiFi PCI-cards....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
i maintain your card in photo is so sexy compared to my 4650 (yuk) which cant cope with BF2 at medium settings. i shall be trying that L4D soon though, looks good - also do want to get COD4 - i'll try joining you for a game if we play at same times
questions...
I couldnt see your PCI LAN card on that photo so i thought you had removed it
you clearly have different spec systems in the 410 and 420 and although you might not be able to compare accurately which do you prefer, the XFX HD 4850 or the BFG GTS 250 OC ?
drooling at the impending purchase of EA650 and new gfx card !
and thanks for those photos again!
Chaz
Reply to cps1974
- 0 +
I would say flip a coin, I have both and they are the same IMO.......it's basically a matter of taste....
I would rather have you save up some more money and get either a 4870 or a GTX 260.... the performance that you get for the price is amazing.... but if your budget is 125.00$ or less than go ahead with the 4850 or 250.....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
oooh XFX 4870 512mb found for £90 (just £10 more than the 4850) but I heard these run rather hot and with the other cards in my case (lan card, X-Fi sound card) I though i might struggle for air flow - I guess as long as there is nothing much sitting above the gfx card it should suck plenty of air through the cooling
i shall be taking some photos of my case later too (i'm writing this on the 420 now)
cheers!
Reply to cps1974
- 0 +
The XFX 4870 normally runs cool if you have some decent cable management and airflow.... for that price it's a no-brainer....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
righty the moment of truth is close
expecting delivery of my EA650 & XFX HD 4870 512MB any moment now. shortly i will disconnect to take some photos of my crowded case as it is then if all goes well you'll have some after photos too
I'm right in thinking the EA650 has 2 x PCI E 6 pin cables?
thanks for all your help getting me here!
Chaz
Reply to cps1974
- 0 +
bah goods still not here - last time round they came at 7.45am! new i should have stayed in bed - I have Stella Artois head now!
apologies for the low quality pics on my 2mp phone camera :cry:
here's my current cards - once i sort the cabling out i should be good to go with 4870 when it arrives
http://s660.photobucket.com/albums [...] C00043.jpg
http://s660.photobucket.com/albums [...] C00041.jpg
couple of questions related to the next 2 shots...
http://s660.photobucket.com/albums [...] C00045.jpg
it seems as though the black and gray cables you can see connected to the audio / video front panel above are connected at the other ends to my m/board (grey) and tv tuner card (black), given i never use the audio / video front panel should i disconnect these - indeed the grey one plugged into my m/board now was unconnected when i looked so I decided to connect it up - can i just remove these if they are not in use?
http://s660.photobucket.com/albums [...] C00044.jpg
http://s660.photobucket.com/albums [...] C00046.jpg
and my last question for time being for folks with far more knowledge than me... when I get the new PSU should I leave all the current connectors / cables in place and just replace the PSU block or do I need to remove all and reconnect with the new cables / connectors that come with new PSU?
thanks again!
please hurry up parcel delivery man !!
chaz
Message quoted 1 times
Message edited by cps1974 on 08-29-2009 at 10:56:37 AM
Reply to cps1974
- 0 +
ruddy 'eck I can't even post images properly! can anyone see them ?
Reply to cps1974
Try this
[img]insertlinkhere[/img]
Reply to Delluser1
- 0 +
thanks again!
chaz
No worries, I can see the pics just fine by clicking on them...
As far as the audio and vid cables, I would leave them alone.. You never know if they will be needed in the future... My front audio ports are connected to my sound-card due to I use my headphones almost every day.... If the cables bother you then yea you can disconnect them and tuck them away for future use.... It's all up to you....
Hehe i see you are kinda desperate for your shipment to come in...... I get the same way too trust me.... ;)
As far as the PSU, yes you have to disconnect everything, remove the old PSU, install the new one and reconnect everything back up.... It's really easy just make sure you label the connectors on your existing PSU just in case you need to know where the new one's go....
Message edited by OvrClkr on 08-29-2009 at 07:39:20 PM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
hey mate!
it all worked out great! i'll take some photos when i get out of bed proper (cant sleep, 6.30am here) now have XPS 420 with EA650 and HD 4870
my stupid because i clicked on the wrong ship to address - it went to my mothers house (10 mins walk away) but you should have seen my face before i realised - iwent on the courier track site and noticed soemone had signed for the goods and their status was delivered, i was swearing some bugger had stole them!
all seems to be well, 1 minor problem is the ea650 lacking ATA connectors (for my CDRW and DVDRW drives) so I need to purchase 2 x LP4 (molex ?) to ATA connectors
otherwise all good cos i own the original disc of Battlefield 2 and I can play from a mini DVD image file I have !!
many many thanks, your help has been great! i now have now upgraded my XPS 420
Message edited by cps1974 on 08-30-2009 at 08:07:10 AM
Reply to cps1974
- 0 +
i think I need these to connect up my optical drives...
[url=http://www.ebuyer.com/product/158874][/url]
can I use any of the spare molex - and where you have several molex in a chain must I use the 1st or last one? or any?
you should have seem my smiling face yesterday when i was done switching the PSU ! can't thank you enough OvrClkr
Reply to cps1974
- 0 +
yea you can use any molex plug,,,, it don't matter..... that's what they are for...
im glad it worked out for you, now have fun.... cheers mate!!!
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
sweet, i got my 2 x molex to (S)ATA and I bought myself COD4 (insane fun)
all seems to be going well, if you fancy a game some time (not sure what time zone you are) I am
P__K (2 x underscore) in both COD4 & COD5
PerfectKill in Battlefield 2
OvrClkr you are a star!
Reply to cps1974
- 0 +
Heh, looks like the upgrade went pretty smooth.....
Try taking some pics of you new card when ever you get a chance..... [:jaydeejohn:5]
Message edited by OvrClkr on 08-31-2009 at 04:21:27 PM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
NEW PSU, kudos to OvrClkr! Antec Eartwatts 650W inside Dell XPS 420 case
http://i660.photobucket.com/albums/uu329/cps1974/DSC00048.jpg
Reply to cps1974
- 0 +
nice!!!!!!!!!!!!!!!!!!!! make sure you tuck away as many cables as you can, you need some clean airflow exit'ing the rear of your case.....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
yup hearing you, going to get some cable ties going !
Reply to cps1974
- 0 +
yea cable ties will do the trick [:jaydeejohn:5]
Message edited by OvrClkr on 09-01-2009 at 01:30:01 AM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply - Dell XPS 420 (UK)
There are 593 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
