well i want a 4890, and i tried to figure out what the power supply requirement is "seeing as newegg does not want to say" and i heard that some people, depending on the age of their power supply, could use it well with 500w........my rig is a core 2 duo at 3ghz, the 500w thermaltake psu, 4 120mm fans, 1 200mm fan, blue sound activated lighting, a 9600gt, and 2 gigs of ram.....here are the links to the card and the psu.....sadly, im 40 bucks shy of getting a new psu, which would make things a lot easier
it is made by a company, cant remember the name, but they give you 2 12" light bars with velcro stickers that you place wherever, then you put the sound module "sold if you buy a combo" somewhere that it can easily pick up the sound of your speakers (i unscrewed the backing, put it in an epansion drive using a large drive to small drive panel and re-screwed and now its on the front, sadly though, there is an annoying square space that the module didn't take up) but it has a sensitivity dial and an off, on, sound ctrl, and flash settings
