Need Case Modding Ideas!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need Case Modding Ideas!
Hello all :)
Ok, I have a computer class in school and the current assignment is to come up with an idea for a case mod, and we are actually going to make it in class.
So I need your help in coming up with either a unique or cool looking, yet relatively easy-to-build idea, and DEFINATELY not very expensive idea for either making a case from scratch, or an object (ex. trash can) that I can turn into a computer case. Something like $50 or less (hopefully).
Thanks in advance!
Message edited by ElectroGoofy on 08-27-2009 at 10:26:12 PM
------------------------------ OS: XP SP3. CPU: AMD Athlon 64 3000+. Mobo: VIA k8m800, socket 754. Ram: 1gb PC2100 (133mhz). Video card: Nvidia GeForce 6200. Sound Card: Diamond Xtreme 5.1. PSU: A Power Golden Deluxe 580W.
And THAT is the reason I am wanting to get a new computer ;)
Sponsored Links
Check out the many mods that are available by pro's such as MonsterMawd,etc. (Google for his youtube vids)
http://www.xtremesystems.org/forum [...] p?t=197014
Guides:
http://www.xtremesystems.org/forum [...] p?t=197016
Message edited by shadow703793 on 08-27-2009 at 10:40:17 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to shadow703793
+1 ^5 what Shadow703793 said.
MonsterMawd at mnpctech.com has some really great video clips over at youtube.com. I looked at bunch of them the other day. Also try searching Google for case mods. I found some really great stuff, including the Victorian keyboard and monitor seen on "Warehouse 13" on the SyFy Channel (new name for Sci-Fi).
Message edited by JohnnyLucky on 08-28-2009 at 01:42:29 AM
Reply to JohnnyLucky
What about an amazing side window mod?
http://www.tomshardware.co.uk/foru [...] l#t1834893
That's one of the very best I've ever seen ^^^.
Either custom paint the inside.. or cut out and make a window.. of it it's already got a window then I'd do something like the above link shows.
------------------------------ XFX 750a SLI | PHENOM II X3 720BE (@2.91GHz) | 2x GTX260 core 216 896MB | 8GB 800MHz DDR2 | Creative Audigy SE | 1100W PSU | 640GB Boot | 1.2TB Backup
Reply to acer0169
Ok, thx all, keep the ideas coming! :D
Reply to ElectroGoofy
Ok, I am thinking I might go with a hard sided suitcase, or maybe a see-through computer case..... but still looking at all suggestions :)
What happened to actually doing the work your self?
Man I'm getting old, lol
Reply to sportsfanboy
Go to sites like BT, TBCS, and OCN, and look at the worklogs.
Reply to ShtBrix
Ha, yea, I have been thinking and have come up with a couple ideas, but just wanted to hear somebody else's ideas, seeing as how there are a bunch of case mod pros on here ;)
Going to check them out right now! :)
Recycling of old/outdated appliances should still be a good mod. Looking around my place an old window mounted air conditioner, old file cabinet or old toolbox. Maybe a mobile idea like a wheeled carry on type luggage bag, a wheeled pressure washer or wheeled tool cart. You might make a stop at your local dump or a thrift type store and see what's a usable size and shape and cheap$$.
Reply to dirtmountain
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need Case Modding Ideas!
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
