Hi all,
I have recently overclocked my Q9550 to 3.4ghz from stock 2.83ghz and i'm currently running Prime95 to stress test the overclock to make sure it's stable.
So far after 2.5 hours it's running fine, however I am a little concered over the temps my cpu are reaching.
Real temp advised it peaked at 75c a few times along the test, often it will decrease to 68-70 not long after and then up and down through the test ofte n hovering at around 60-70c for the majority of the time.
Core 1 reaches temps 6-8c hotter than the other 3 cores, is this normal? The others havnt gone above 67c for the whole test.
Here is my system:
Case: Thermaltake Aguila - http://www.kool4it.com/thermaltake/cases-mid-tower-/thermaltake-aguila-vd1000bns-black-case-p-358.html?osCsid=mjsopa67ep7cmc1jg0a658jiq5
Motherboard: ASUS P5N-D
CPU: Intel Core 2 Quad Q9550, overclocked to 3.4ghz, 400mhz BUs speed, 1600 FSB
My Case has a thermaltake 120mm fan on the front and another on the rear, im adding a 80mm to the side soon.
I'd like to know if you think it's worth me upgrading my CPU cooler, and/or case fans given these temps and the speed i'm overclocking at or will I be ok as-is?
Here is my system:
