Tom's Hardware > Forum > Homebuilt Systems > New System Build > First computer building need help
Forum Homebuilt Systems : New System Build - First computer building need help
My question is would this system work together and is it the best system for the money?
SAMSUNG Black 22X DVD-22.99
http://www.newegg.com/Product/Prod [...] 6827151175
COOLER MASTER Centurion 5 CAC-59.99
http://www.newegg.com/Product/Prod [...] 6811119077
Western Digital Caviar SE16 WD5000AAKS 500GB- 59.99
http://www.newegg.com/Product/Prod [...] 6822136073
ECS BLACK SERIES GF8200A- 79.99
http://www.newegg.com/Product/Prod [...] 6813135085
EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB- 104.99
http://www.newegg.com/Product/Prod [...] 6814130325
Thermaltake Purepower W0100RU 500W -59.99
http://www.newegg.com/Product/Prod [...] 6817153052
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800- 46.99
http://www.newegg.com/Product/Prod [...] 6820145184
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler- 31.99
http://www.newegg.com/Product/Prod [...] 6835186134
AMD Phenom II X3 710 2.6GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Processor- 119.99
http://www.newegg.com/Product/Prod [...] 6819103648
Microsoft Windows Vista Home Premium SP1 32-bit- 99.99
http://www.newegg.com/Product/Prod [...] 6832116485
Thanks for help and is this good system for price my email is ajb415@gmail.com if anyone wants to send some tips.
Sponsored Links
Get this drive (larger and faster for a few$'s more) instead:
http://www.newegg.com/Product/Prod [...] 6822136319
The ACF7P is a great economy cooler, but for a few $'s more:
http://www.newegg.com/Product/Prod [...] 6835233029
Reply to jsc
Jsc do thes parts work well together?
Reply to alexgreat
Is my motherboard ok or should i go with a better known brand?
Reply to alexgreat
anyone wanna give some input?
Reply to alexgreat
ECS is a terrible brand. Their boards are the cheapest of the worst, or worst of the cheapest.
Grab something like a Gigabyte or ASUS.
Spend the extra bit of money and get the 720 processor. You appear to want to overclock, and it will be much easier with the 720. You may also want a better cooler, something like a Xigmatek Dark Knight is still cheap and is very good.
I'm not a fan of buying older video cards, I'd go with a GTS250/9800GTX+, HD4770 or HD4850.
Reply to Fortunex
- 0 +
I have looked at some of your components, and I can see several upgrades that you should use instead of what you have planned. Take a look at my thread. I've done significant research on the best components for the money. Also - what is your budget?
http://www.tomshardware.com/forum/ [...] build-1000
Here are some pointed suggestions that I can say directly.
GPU Radeon 4770 is likely to out perform your 8800
RAM Suggest DDR3 RAM, not DDR2 - better performance for not much $$
OS Why 32bit OS? If you are purchasing - get the 64bit!!
HD For $10 you can get a 750GB HD - if you need the space, it isn't much $
CPU Get the X3 720 CPU - it will be Black Edition - therefore you can OC, and also it has a higher base at 2.8 vs 2.6GHz
I'm open to hearing your responses
Reply to mikeyp
ok my budget is about 600 to 650 dollars and the reason for 32 bit os is becasue i get 20 dollars off and heard some bad stories about drivers for 64 bit
Message edited by alexgreat on 05-25-2009 at 11:14:24 PM
Reply to alexgreat
i dont really want to overcock just want to keep pc cool lol, also changed motherboard to ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard for about 10 bucks more.
Message edited by alexgreat on 05-25-2009 at 11:15:55 PM
Reply to alexgreat
- 0 +
I'd go for the 64 bit. It's just $20 and you'll thank yourself when you decide to install more than 3GB of RAM. As for drivers, stick to the bigger brands for Video and MB and you should be fine. 64 bit has been around long enough and is gaining enough market share that vendors are paying attention.
Besides, it is basically where things are going, especially since 64 bit software and hardware can theoretically address 1.8 billion GB (1.8 petabytes i think) as opposed to only 4.2 GB with 32 bit addressing.
Reply to mr_tuel
MSI R4850-512M OC Radeon HD 4850 512MB 256-bit GDDR3
http://www.newegg.com/Product/Prod [...] 6814127401
will this be better or worse than the 4770? and i cant find the 4770 so are there any near that price range that are as good as the 4770.
Reply to alexgreat
4850s are a little better than 4770s, but consume a little more power and run hotter.
Reply to Fortunex
so would the case have listed with an extra fan and 550 watt power supply suffice?
Reply to alexgreat
- 0 +
This build down below allows you to add another 4770 later on for Crossfire if you so choose. This psu is not only modular, but it meets ATI's requirements for the 4770 in Crossfire. This build also allows you to over clock. :)
http://www.newegg.com/Product/Prod [...] 6811129042 $58.95 Free Shipping*
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6817341022 $74.99 ($49.99 after $25.00 Mail-In Rebate)
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/Comb [...] mbo.190734 Combo Discount: -$30.00 Combo Price: $218.99
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX - Retail
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6835233014 $24.99 Free Shipping*
XIGMATEK HDT-SD964 92mm Rifle CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835154003 $4.99
Tuniq TX-2 Cooling Thermal Compound - Retail
http://www.newegg.com/Product/Prod [...] 6814102835 $99.00
SAPPHIRE 100277L Radeon HD 4770 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6820231166 $54.99 Free Shipping*
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6822136074 $54.99 Free Shipping*
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6827136152 $23.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
Total: $616.87 | $591.87 w/mail in rebates
http://technet.microsoft.com/en-us [...] ID=mscomsc <--- Save yourself some money on an o/s and dl the 64 bit version of Windows 7
http://www.tomshardware.com/review [...] ,2281.html <--- 4770 benchmarks
http://www.tomshardware.com/review [...] ,2288.html <--- 4770 Crossfire benchmarks
http://www.sapphiretech.com/presen [...] 01&pid=251
Reply to Why_Me
That video card is sold out and i was told not to get a gigabyte motherboard and can you explain whole windows 7 thing im a noob i know
Reply to alexgreat
- 0 +
If you don't have an o/s (Windows) then you can dl window 7 on a pc or laptop (you want 64 bit), and then burn it to a disk and use that for your operating system...saving you like $100. As far as Gigabyte boards go, they are a very trusted name. Read the reviews on them....like the ones on newegg. I'm not sure who's giving you advice, but if it's the same person who was talking about drivers for 64 bit then I wouldn't listen to that persons advice. XP 64 bit might have crap drivers, but Vista 64 has excellent drivers and support. Then again anyone still using XP to game with needs their head examined. If your going to game you want a 64 bit o/s to read all of your memory, and of course Vista and Windows 7 support DX10.... DX 11 for Windows 7. So ya it's the year 2009 and this is where it's at if you want to game on a pc these days. XP is cooked and done for, and 32 bit o/s are good for office machines with less than 4 gigs of memory.
http://www.eworldsale.com/sapphire [...] 31995.html
http://www.eworldsale.com/msi-r477 [...] 31898.html
http://www.allstarshop.com/shop/pr [...] &pid=23485
Reply to Why_Me
ok so how long wont i need an operating system?
Reply to alexgreat
all link are out of stock
Reply to alexgreat
- 0 +
The beta expires March of 2010...after that you have the option to pay for it, or let it expire. So ya, your getting a free o/s until then.
Reply to Why_Me
Im going to order my computer parts tomorrow so i have taking your guys advice and got a Asus motherboard and a better hd (specs below), My final question is i am in my price range but with the 2.6 triple core cpu and a 8800GTS 525 MB video card if i am to upgrade one what should it be and why?
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Reply to alexgreat
is the beta have many glitches or what?
Reply to alexgreat
no i'd say its pretty stable. i have a similar build to yours except i have a gigabyte motherboard. excellent motherboard might i add, never given me any problems. i have the 8800gts but the 320MB version and i have an intel core 2 duo e6550. windows 7 (64 bit) runs well and i have not had any driver/stability problems since i installed it a while ago. im still able to play all my games and i've not had one issue with the OS so far. i would say go with the OS until march 2010.
Reply to elchuchopisado
Are MSI motherboard good? link below is one i am looking at
http://www.compusa.com/application [...] CatId=2320
Reply to alexgreat
^ that one isn't, and the only praise I see on MSI motherboards anyway is on the X58M so it's best to stay away from MSI.
Reply to Helloworld_98
ok, so i would be good with this one and any other people wanna give input on why or why not this motherboard is good
Reply to alexgreat
- 0 +
I originally bought a ASUS M4A78 Plus motherboard and it was no good. After terrible customer service from both the vendor and ASUS, I returned the board and bought myself a ECS GF8200A Black Series which is working wonderfully for me.
Reply to eiko
There are 971 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
