Dual screen problem
poisoborz
14
Hola,
Right now I have a 22' TFT monitor, and a 19' CRT lying around. I thought I could hook them up as a dual screen setup, but the results were not really good..
I have an nvidia 9600GT graphics card, and tried to set things up trough it's nview app. Is it really impossible to set the two screens to different resolutions/refresh rates?
My TFT goes on 1680x1050, and the CRT 1280x960 (refresh rates are 60mhz and 100mhz).
Whenever I tried to set things up, I could only set one resolution and refresh rate... (settings for the other monitor were disabled)
Is this a software (nview's) issue or this is natural?
505090
1,575
if you are using xp go to display properties, then settings. each monitor should be shown click the different monitors will allow you to set the settings of each independently.
