Tom's Hardware > Forum > CPU & Components > CPUs > Spontaneous Reboot Problems, Help?
Forum CPU & Components : CPUs - Spontaneous Reboot Problems, Help?
I have a newly built system (a few months old):
Core2 Quad Q9400 2.66GHz
Gigabyte GA-EP45-UD3P mobo
Artic Cooling Freezer 7 Pro CPU Cooler
Cooler Master RC-690 Mid Tower Case
Cooler Master UCP RS700 700w power supply
Running Vista Ultimate
Can someone help me troubleshoot a spontaneous reboot problem? It occurs usually when I'm doing heavy data processing (using Stata, a statistics program). However, it doesn't appear to be a heat issue (monitoring using Gigabyte's EasyTune 6 while executing heavy statistics code, doesn't reveal temperatures above 100 F, yet it spontaneously shut down/reboots!
What else can cause this? Note: I have NOT overclocked or edited any CPU settings (that I know of).
Thanks for your insights!!
Sponsored Links
Do you get a quick blue screen or does it just reboot?
Reply to sportsfanboy
Nope, no blue screen. Just an instantaneous reboot.
Reply to mayan50
Do a load test with real temp and see what the temps say...
Make sure your ram is set up properly- timings and voltage to manufacturers specs
I would say a good majority of problems in regards to computer stability can be blamed on the ram if not properly setup.
Will do.
Where can I find the best BIOS settings for my ram?
I have 4 sticks of G.SKILL F2-6400CL5D-4GBPQ
Reply to mayan50
You'll have to check your receipt/box for the timings/voltage.
If you don't have the specs you can always call the manufacturer and they will tell you.
Thought this would be a common config of a common mobo with common ram. Looking at the GSKILL forum, sounds like some tweaks are needed. I just want to be able to run 8GB of ram, stable, without overclocking. What happened to just plug and play ram?
I've run Memtest86 v2.11-- with all 4 sticks in I get errors beginning on Test 3. I am now testing 1 stick at a time in slot.
My timings using AUTO in BIOS match settings by GSKILL- 5-5-5-15, 1.8v-1.9v
Other suggestions?
Reply to mayan50
use the rated timings and voltage for now, and set the northbridge to 1.4
Sometime you need a northbridge bump when using more than 4gb of ram
Now this is weird.
So I tested each stick separately in slot 1 with memtest 1 pass, all good.
Then I put all four back in, and I'm testing Memtest, at Test #5 (33% of 1 pass with ZERO errors). Maybe one of them was dislodged?
Is the Northbridge, the MCH Core setting to 1.4v?
Reply to mayan50
Yes, try that out and check stability again. If that doesn't work, try upping the ram voltage 1 notch.
There are 927 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
