Please provide comments if there is likely to be hardware conflicts. I'm extremely concerned that I missed something in my plans, and I don't want to drop the money into my first system build and find out something doesn't fit because I overlooked some silly detail.
I would be very happy is someone just simply said - Good plan, this will work well for what you have planned.
Goals of the machine:
1. All around general use - I do not have excessive storage needs, minimum is 500GB
2. Games - I'm tired of low FPS. I will plug this into my HD TV, so I need respectable frame rates at 1920x1080. I'm willing to accept lowered details, but I want it to look good.
3. Possibly function as HTPC in future - with the addition of a Blueray drive.
4. Budget - want the best components for the money - willing to spend extra if there is substantially better at a reasonable increased price.
Approx Pruchase Date: Today/Tomorrow - VERY SOON - Approx Price ~$1000
System Usage: General Use and Games (I want adequate gaming performance and will build as such), any gaming machine I purchase will cover my general needs. As an after thought, I might use it as a HTPC in the future, though I will not design for this need.
Parts Not Required: Keyboard, Mouse, Speakers, Monitor (will use HD TV for monitor, need to plan for 1920x1080 GPU performance)
Preferred website for Parts: NewEgg I priced all of this from newegg and at least 3 other sites, and newegg is within 5-10 on each component if not the lowest priced. I will order from another site if it is recommended, however they must be competitive on pricing, and come with a recommendation that they also have good customer service.
Overclocking and Crossfire: Will plan to overclock (as presented in the building guide. Initially I will run stock numbers, and if performance is adequate, I may wait some time before I start dialing up the speeds, but I do plan to OC this machine either now or in the future, I see no reason not to after my mfg warranty is off. X-fire initially is not planned, due to price. I am planning on adding a 2nd GPU when I have the money.
Monitor Resolution: HD TV as monitor 1920x1080p is preferred. Will consider alternatives, but this system is expected to game at that resolution. Will accept lowered details, but expect adequate frame rates. Will plan to X-fire in future for additional performance if necessary.
Additional Comments: Just tell me all the components fit together and will do what I expect them to do, and I'll be very happy, and will have the confidence to order them.
Part Preferences:
Case: Antec 1200 Gaming Case - Big with great air movement.
PS: Antec EA-750W - Combo deal with case and provides quality and sufficient power for this system - see above url
CPU Cooler: Zalman CNPS9700 - This cooler is time tested and performs near the top for air
CPU coolers - noise levels are predicted to be reasonable
Thermal Paste: Rosewill RCX-TC060 - This paste has the highest heat transfer rate I can find, even slightly out paces Artic Silver by my research
CPU:AMD Phenom II X4 955 BE - Good OC Potential
RAM: CORSAIR XMS3 DHX (2x2GB) - On Combo deal with CPU, will consider going to Crucial Ballistix in the future if this does not OC well for me See URL above with Combo Deal with CPU
RAM Alternative: Crucial Ballistix (2x2GB) 6-6-6-20 DDR3-1333 BL2KIT25664BA1336
MB: MSI 790FX-GD70 - AM3, good review from Tomshardware, has PCIe 2.0 16x and 16x Crossfire Potential, has 790FX chipset with great OC potential, alternative would be the MSI 790GX-G65 MB
HD: Western Digital Caviar Black 1TB 7200RPM SATA Drive TWO in RAID 1 Config. Overpurchased on the HD, so that I can RAID 1 instead of RAID0 them. 1TB will currently be more than sufficient HD Space, and RAID1 should out perform RAID 0 for read functions, it is unlikely that writing will bottleneck this system in the near future, and I will gain data redundency incase a drive fails - I will also maintian a separate backup incase the whole thing goes down.
GPU: Radeon 4770 GPU - given one of the best value for money ratings currently available. Will likely run 1920x1080 resolution at reduced detail levels until I can Crossfire in a second card.
Optical: Will currently use an existing IDE DVD-ROM until I can add a Blueray SATA Optical Drive
Current Price all from NewEgg is 1059, which is right where I would like to keep it. Suggestions are appreciated.
