Solved
Looking for cooling solution to overclock
April 8, 2011 4:31:25 PM
Please provide suggestions to new system build for cpu cooling, thanks in advance. Let me know if additional infomation is needed. Looking to oc low to mid as new to oc'ing.
Mainboard MSI 890FXA-GD70
Processor AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
Cooling AMD Stock cooler
Ram Cosair XMS3 2GB 1600 CMX4GX3M2A1600C9 x4 total 8 Gig
Case Rosewill Challanger
VGA MSI N560GTX-Ti Twin Frozr II
PSU Cosair CMPSU-650HX 650w HX Series
OS Windows 7 Home Premium
CDRW Samsung DVD+RW Optical Drive SH-S223L/BEBS x2
SATA Western Digital WD1002FAEX (Main drive)
SATA Seagate ST31000524AS (Backup drive)
April 8, 2011 6:20:08 PM
you can use extra cooling fans.
m
l
April 8, 2011 8:17:32 PM
I was thinking more of a CPU HS solution, thanks
m
l
April 13, 2011 11:35:41 PM
Thanks lowjack, I will consider your suggestion.
Anyone else with suggested cooler that will fit case & MB? I figure I only have about 120 mm or so clearance.
thanks all,
m
l
April 14, 2011 4:18:45 PM
mouse24, thanks for your input. I considered this an option early on but had to cross it off the list as the overall height was 158-159 mm (6.25 inches) My other consideration was Arctic Freezer 13 Pro but still had height issues. Now looking at and checking reviews to Arctic 13 as this is only about 130 mm (5.25 inches) tall. I also looked into the Corsair H70 and think the radiator wont fit in case either except maybe the side panel to the case.
Other suggestions are welcomed.
m
l
Best solution
a c 183 K Overclocking
April 15, 2011 1:36:06 PM
April 17, 2011 2:06:09 AM
Best answer selected by DAXMMX.
m
l
April 17, 2011 2:16:26 AM
Thanks all with all your suggestions, my final selection was Noctua NH-U9B SE2
Reasons for selection Noctua site confirms it will fit my MB and height is well below the CM 212+ I liked reviews for this from many other sites and Noctua gets good reviews for their product line.
Special thanks to Davcon as he made me think of more ways to search for solutions, and also to all that take time to help on the forums.
If I can figure a way to post before and after pics I will try.
thanks again,
m
l
April 17, 2011 2:30:05 AM
thanks again,
Thanks for the BA and i can't argue with your excellent choice!
Cheers:)
m
l
