Hello, community.
I've had several PC's before, but none of them ever had a case fan.
Including my current, wich is well overclocked (E6400 form 2.13 to 3.20 Ghz on air), and still no case fan of any.
I'm about to buy a new PC, with core I7 940, intend to overclock it.
Question: Should I really buy a case fan this time ? I'm quite sensitive about noise, so I try to keep things as quiet as possible...
Yes If you want to reduce noise. Legitimately case funs are used to keep PC's cool and quiet. And if you want to overlock then I reccomend getting some. They are cheap as well around $5-10$ depending where you live.
Well, I know there are silent pc's that do not have case fans for extra cooling. I also know there are some pc's that do not have cpu heatsink fans or power supply fans either. I'm not sure if it would be appropriate for a new Intel Core i7 system and serious overclocking. In fact, I'm not even sure if it can be done.
Message edited by JohnnyLucky on 08-30-2009 at 05:43:34 PM
Adding a quiet fan, even with low rpm in the case and help extract the hot air from within the case, thus causing the internal CPU/PSU fans to slow down, meaning that the whole thing can make less noise with the extra fan than without.
------------------------------CPU: PhenomII X4 955 BE ; RAM: 8GiB
OS: BSD, Linux, Solaris & Windows (use VirtualBox)
Reply to Devastator_uk
There's plenty of fans out there designed to shift a lot of air without making too much noise. Scythe Gentle Typhoon springs to mind.
To be honest though if you're looking at overclocking a Core i7 system then you're just going to have to make some noise unless you watercool everything - you need to shift the heat these things produce, and fans are the only way of doing it.
And as a little aside, don't bother with the i7 940 - every i7 other than the 920 is a waste of cash because the 920, especially the D0 stepping, just overclocks like a motherbitch and you can match, if not outperform even the Extreme Editions.
If you want to go faster than 2.7GHz without overclocking then go for the 950 instead - it's D0 stepping as opposed to the 940's C0 so marginally easier on the power and heat fronts and costs a touch less too. But honestly you can whack a 920 D0 up to 3.8GHz with a lapped TRUE or Megahalem with some 1200RPM fans and cool without making too much of a racket. Assist the case air flow with some high-volume, low RPM big fans (180mm and up if your case allows it) and you should be OK.
Thank you LePhuronn Actually, I already bought a Sunbeamtech Core Contact Freezer 120mm for the cpu, I wonder what you opinion on that would be ? It cannot be lapped because of its special design but they say it still performs wonderfully. I plan to lap the cpu though.
So you say that there's no difference in how high I could get the clock , between 920 and 940 ?
BTW, how can I be sure that what I get from our provider is a D0 specimen ?
Message edited by Innuendo on 08-31-2009 at 09:44:24 AM
There are a number of cases out there that have plenty of fans are are still almost inaudible. I recently built a machine using the CoolerMaster HAF 932 which has 3 - 230mm and 1 - 140mm case fans and it is barely a hush even with it 2.5 feet from me sitting on my desktop.
Quote :
Not sure there is a way to request a D0 stepping, that may depend on the retailer. However, the i7 920 I ordered from Newegg at the end of July was/is a d) stepping. I would imagine at this point almost all i7's sold are D0.
