Tom's Hardware > Forum > Homebuilt Systems > New System Build > New Gamer System build. What do YOU think?
Forum Homebuilt Systems : New System Build - New Gamer System build. What do YOU think?
Hello
I'm ready to order a new computer.
I build this, what do YOU think?
Any suggestions or experience?
Intel Core™ i7-920
Asus P6T Deluxe V2, X58,
Corsair Dominator DHX+ DDR3 1600MHz 6GB
Corsair Powersupply 750W Black, ATX/EPS,
XFX Radeon HD 4870X2 2GB (Heard about the brand? Good?)
BenQ 24" LCD E2400HD
Logitech G15 gaming keyboard
Logitech MX518 Optical Mouse,
Western Digital Caviar® Black™ 640GB
eSata 3 Gb/s, 32MB Cache, 7200RPM
Antec Three Hundred (cabinet)
Any suggestion request for change?
Experience?
Morten
Sponsored Links
Change the monitor to a Asus 24"
Ram To G.skills DDR3 1600/CL:8-8-8-21
PSU: Corsair or PC Power&cooling(red case) 750w is fine.
The P6T deluxe v2 is mostly good for a nice overclock, do you plan on doing that?
Case: RC-690 for a little more room
The BenQ could be fine but, asus is a good brand for Monitors.
Message edited by fullmetall on 05-26-2009 at 06:36:35 PM
Reply to fullmetall
XFX is one of the best gpu brands. They offer double life-time warranty, so you are good2go there.
Reply to dannyboy33
- 0 +
It looks like you did your research, the build looks pretty good.
I'd change the ram though. This Muskin stuff is at 7-8-7-20 timings 1.65v@ DDR3 1600.
http://www.newegg.com/Product/Prod [...] 6820226030
Also the case might be a problem for that long card. I heard that they are a really tight squeeze in the Antec 300.
Reply to effel
- 0 +
The case might be a problem, are you planning on overclocking?
Reply to sassan
- 0 +
mortenstj wrote :
Hello
Intel Core™ i7-920
Experience?
Morten
http://www.tomshardware.com/forum/ [...] ild-advice
What's your budget, what country are you in...you could be in China for all we know....do you intend on over clocking...etc... Your build could be a good one, or it could be pure crap depending on your budget and intended needs.
Reply to Why_Me
I live in Norway.
I'm not planning to extreme overclock. I want a all-round computer for games, movies. etc.
I don't think the system will be pure crap anyway
Reply to mortenstj
^ are you kidding? that system is one of the best for gaming.
Reply to Helloworld_98
- 0 +
^+1...
What is the cost of the 4870X2, GTX 275, HD 4890 there?
Reply to gkay09
well that Corsair Dominator ram supposed to be good for overclocking. if you look into the recommended G.skill ram make sure its good for overclocking and if is get it because i'm sure it will be cheaper
Reply to captaincharisma
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
