Tom's Hardware > Forum > CPU & Components > CPUs > Guide Me Build My New PC for GAMERS
Forum CPU & Components : CPUs - Guide Me Build My New PC for GAMERS
Hi all please help me to build my new PCs for gaming...:)
Motherboard : GiGaByte GA-EP45T-UD3P or GA-EP45T-UD3LR <== Which should i choose?
Graphics Card : "Saphire ATI RADEON 4870 1 GB" or "NVIDIA 9800 GTX 1 GB" ???
Memory <== I don't have any idea about this. i prepare using DDR 3 1033. Could anybody tell me which brands are compatible with that Motherboard?
Processors <=== E8400
PSU <=== i don't have any idea about this too...
Please your help to guide me build my new PCs for Gaming... :D
Thank you
Sponsored Links
I don't agree with the use of that "guide" since people's intended uses and their expectations are far too diverse to just give a "suggested" build for a specific price range.
Please post your intended uses and price limit.
Reply to The_Blood_Raven
Personally, I wouldn't get Core 2 at the moment. I'd look at either the Core i7 for out and out performance, or AMD for value. Core 2, and the socket 775 motherboards, are reaching the end of their useful lives.
Tell us your budget, we'll take a look. I will say in advance that I think if you're looking at that sort of price point for a graphics card, I'd look at a GTX260, or the 4870.
Reply to DeeTee_uk
Okay my budget is between 500 - 600 $$$ ... This budged are only for few components, those are :
1. Motherboard
2. Graphic Card
3. Processor
4. Memory
5. PSU (this is optional, but i also hope you can suggest me which is a good choice)
Please give your suggest ... ^^
Thank's
Message edited by witecloner on 08-31-2009 at 03:02:55 PM
Reply to witecloner
I would purchace this psu for under a hundred dollars
http://www.newegg.com/Product/Prod [...] 6817703016
It has 35amps on the 12 volt rail as opposed to 27amps on the budget build in the guide. A little more money, however it will provide more upgrade-ability
Reply to sportsfanboy
OK. I would (personally) go for:
AMD Phenom II X4 3hz CPU with the GIGABYTE GA-MA790FXT-UD5P bundle here:
http://www.newegg.com/Product/Comb [...] mbo.237638
Frome reviews, this board overclocks well too, so if that's your bag, you're in luck. If it's not, the option is there if you feel more confident later.
Sapphire Radeon 4870 found here is the Vapor X one, for about the same price as the standard one:
http://www.newegg.com/Product/Prod [...] 6814102825
In theory, the cooling should be a bit better on this one. I've no experience of it myself, but I do have the normal Sapphire 4870, and really like it.
RAM - 4gb of G.skill DDR3 12800. Can't go wrong really.
http://www.newegg.com/Product/Prod [...] 6820231193
You don't really need any more than 4gb at the moment, but if you're feeling flush in a couple of months, you can add to it.
PSU - 500w OCZ ModXstream.
http://www.newegg.com/Product/Prod [...] 6817341016
$59.99 is a good price for this anyway, but even better with a $20 rebate. I've gone for this one purely because it's a brand I know. The one sportsfanboy recommends may well be better, I just get nervous about a PSU I don't know.
All this comes to $599.95. It's not bad for upgrading later, as the AM3 socket is new, so you should be able to replace the CPU later if you want. You can also drop in another HD 4870 later, and run crossfire when the card is cheaper. If this is something you want to consider, you might want to think about spending slightly more on the PSU ($40) and getting this one:
http://www.newegg.com/Product/Prod [...] 6817341002
or this one:
http://www.newegg.com/Product/Prod [...] 6817371026
The one I've picked will run this system, no problem, but these two should run the crossfire if that's what you want later. I would prefer the Antec one, as it's on AMD's approved list for 4870 Crossfire power supplies, which is here: http://game.amd.com/us-en/crossfir [...] 0HD%204870
I quite enjoyed that actually! I hope it's of some help. Obviously, if you put it all together and blow a hole in the side of your house, that's not my fault. Buyer beware ;)
Message edited by DeeTee_uk on 08-31-2009 at 10:38:04 PM
Reply to DeeTee_uk
There are 1121 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
