Tom's Hardware > Forum > CPU & Components > Sound Cards > Tinny ringing sound from Supreme X-Fi with Rampage extreme
Forum CPU & Components : Sound Cards - Tinny ringing sound from Supreme X-Fi with Rampage extreme
I have a rampage 2 extreme and the sound card that comes packaged with it has never really worked correctly. About half the time after a restart the sound will have a tinny, ringing effect to it. Please advise
Sponsored Links
Mmm... What speakers are you using? I had almost the same problem with a intel bayfield MB(Granted 3 years ago), my logitechs kept making these ticking sounds, but only with them, other speakers didn't do it... Switched the sound card to a SB Audigy, never had that problem again.
Have you tried other speakers yet?
And have you checked your ground wire? Sometimes high pitch whines could be caused by a bad ground connection somewhere.
------------------------------ People say that I'm stubborn but I insist that I'm not. They eventually give in to me.
Reply to N@n0
I am using the optical cable.. Some mirage nanosat's and a panasonic amp. I spent a ton on the speakers so I hope its not them lol.
Reply to sumofugu
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
