Overclock problem
I overclocked my Hd 5670 by changing the bios,games work fine but when i play a video on the internet or on a media player the screen turns black, the pc gets blocked and has to reboot.
The GPU is running on 850mhz and the VRAM on 1100, the voltage is set on 1.6v.
Its not the temperature because its at 33C.
Please help i dont know what is wrong.
8 answers Last reply
More about overclock problem
  1. Some GPU's do not OC well...revert back to default settings....As far as temps go..That 33c you mention would have to be at idle...What are your temps with a load on the card? When OCing GPU clocks they do some weird things when they are not stable OC's...So, that said...you will have to run the GPU at stock or close to stock settings
  2. What procedure did you use to change the bios on your gpu ?
    and how did you get the voltage that high ?
    my 5850 only get 1.087v nowhere close to 1.6v
    try undoing whatever you have done with the bios and go at the overclock with catalyst control center or a tool like msi overdrive or amd gpu clock tool
    33 is idle and the maximum is 42 when playing games.
    i used Radeon bios editor,i tried ATI Override and it has problems running games,but with the bios editor it has no problem with games and it malfunctions on videos.
  5. with rbe make sure your ram clocks are all the same in the corresponding want phase you will notice that certain wants highlight together i think its the non-power save mode you want and the ram settings should all be the same before you flash. but its been a while sorry i cant be more spasific maybe someone can weigh in on that for me
    now when i was mucking about with my video cards i found this cool little trick for msi afterburner boot in to windows as admin locate the msiafterburner.cfg file open it with notepad and locate ( UnofficialOverclockingMode = 0 ) its just about at the botom of the window. Edit that line to be ( UnofficialOverclockingMode = 1 ) 0 is closed 1 is open when that’s done log back into your user and open msi afterburner. In the setting menu you can unlock the voltage as well with this you can do all your overclocking without flashing the bios and voiding your warranty.
    making this change to afterburner makes it a verry cool tool
    i hope you backed up your original bios so you can flash back if you need an rma
  6. http://www.techpowerup.com/vgabios/ if you didnt back up the bios this may help you find one
  7. Ok il see what i can do, thanks for the information.
  8. I am also facing a problem of almost similar nature, what is the exact cause of it....??
Graphics Cards Overclocking
