Hello!
Just recently finished to build my system.
The spec:
Intel C2D E8500
Biostar TPower i45
2x 2GB Patriot DDRII 800
Xfx GTX260 (Black Edition)
HDDs > 320gb + 1.5tb
dvd-r/rw
Chieftec super series 650w psu
The problem is, that with this setup when I press the power button on my case the system successfully starts only after the 2nd/3rd restart. The first 2/3 times it starts up, runs for a few seconds than turns off, starts again and shuts down again till in the 3rd or 4th try it boots to the OS successfully. After that everything is running smooth without any problems.
So far I discovered, that, if I put a weaker graphics card (my old xfx 7900gt/gto) it starts as it should. I tried to put a different PSU (my old FSP bluestorm II 500w and connected only to the vga, mb) and I still have this "starting error".
I'm totally confused at this point.
P.S. Getting the gtx260 to the reseller is the current plan of action.
The spec:
Intel C2D E8500
Biostar TPower i45
dvd-r/rw
