Help me overclock my i5 2500k budget system!
Hi guys! I'm coming in hot from a Q6600 system! This is my first budget iCore series system (450)! Help me get more bang for my buck!
Case: Antec Six Hundred Black Computer Case
CPU:Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
Mobo: MSI P67A-G43 (B3) LGA 1155 Intel P67
CPU Cooler: Master Cooler or Stock CPU Cooler
Graphics: 8800 GTS (temp)
RAM: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
PSU: OCZ StealthXstream II OCZ600SXS2 600W
HDD: OCZ Vertex LE 100GB 1.32 FW
:pt1cable:  :bounce:
Add a cheap CPU cooler like the Cooler Master Hyper 212+. In my opinion, it was the best 30$ I spent on my system. Brought temps down and looks nice too. That'll easily take the heat off a 4.8GHz i5-2500k.
The H50 and H60 will easily outperform the Hyper 212+, but at twice the price of the Hyper 212+. Also, you have an additional point of failure: the water pump. You see, if the fans of the Hyper212+ fail, the system can still go on, because the Hyper 212+ actually works fine as a passive (no fan) cooler, because of its size. But if the water pump of the H50 fails, you'll overheat pretty soon. I'm not saying that the pump will fail so quickly, but it's a thing to consider.
If you think the benefit outweighs the cost and risk, then go for it.
Related ressources
Ah ok sweet. Thanks! I will go with the Hyper 212+!
There are also some other good (and huge) air coolers out there. You can check out the Cooler Master V8, V6, Prolimatech Megahalems/Megashadow, as well as Scythe and Xigmatek coolers (I forgot their names).
ragingazn628 said:
How would I actually go about OC'ing? Do I adjust the FSB like my Q6600 or do I adjust the multiplier?
Do not change the FSB :non:  on the P67 chipset a lot of the components on the motherboard use that as a base clock, not just the CPU and RAM. You have a 2500k, the "k" means that it has an unlocked multiplier and so that is the only way to overclock the CPU :)
Ah sweet! Keep upping the multiplier until I hit a wall? Do I need to adjust anything else?
I dont have any experience with the 2500k/2600k but yes, up the multiplier until it is unstable, then up the vcore. Keep doing that until you achieve your overclock goal. I think the max 'safe' temp for this CPU is around 70*C. Just keep it in the mid 60's and you'll be fine.
There are many guides all over the net explaining in detail how to overclock these CPU's, follow one and you will be golden.
Im running at 5Ghz 24/7 with an i5 2500K.
Im using the MSI P67A-GD65 (non-B3).
Overclocking is easy, yeah you just up the multiplier. Bump your I/O voltage and PLL voltage up to around the 1.2v mark, and give your CPU around about 1.48 or 1.5V.
Set the correct settings for your RAM (usually will be loaded automatically, but you can check).
Enable the "Internal PLL Overvoltage" setting.
Leave your power saving settings ON (really!), although I did disable speedstep (or else it will underclock/devide your CPU to 1.6Ghz when not under load).
The MSI boards are pretty heavy-dudty, so dont worry too much about frying your board. Just open the taps! If you open CPUz under load you will see that the CPU can take a little more voltage when it needs it ;)
Im using a scythe Mugen 2 cooler with 2x120mm fans on it. My temps stay under 70 degrees which I dont think is too bad for a 5Ghz O.C. My cooler is massive, needed a Coolermaster H.A.F. to fit it in (!)
My freind has a Coolermaster V8 and it is OK but really noisy.
Ask the community
