I built myself a system a little over a year ago and everything's been running fine until recently. About a month ago I went to reboot my computer (from within Windows) and it wouldn't boot back up. It beeped once as normal but never sent a signal to the display. I thought the graphics card might be overheating because it felt hot and I was leaving for the weekend so I left it off and then rebuilt it when I got back and took the time to tuck all the wires away. Everything booted up fine and it restarted without a problem for a couple weeks until today when I ran into the same problem. Thinking I was overloading the power supply, I disconnected my two DVD drives but that didn't help. Finally, it booted up after letting it sit for about half an hour.
Here is my system...
E8400 @ stock speeds
Asus P5K-E
Sapphire Radeon HD 2600XT
Antec Earthwatts EA500 500W
Corsair XMS DHX 4GB
Another 2GB of RAM (can't remember brand/model but it's the same timings)
WD Caviar 640GB
WD Caviar 320GB
Two Samsung DVD+/-RW
Creative SB X-Fi XtremeGamer
As you can see, I'm running a lot on a 500W power supply but if that was the source of the problem, I thought I would have problems during use but that's not the case. I thought maybe my graphics card was overheating but today it only took about 30 minutes to boot back up - that wasn't long enough to let it cool down - and it usually runs 24/7 without a problem.
I'm assuming it's a hardware problem because it has happened on both Vista 32- and 64-bit. Any suggestions would be appreciated. Thanks.
Asus P5K-E
Corsair XMS DHX 4GB
WD Caviar 640GB
WD Caviar 320GB
