Tom's Hardware > Forum > Homebuilt Systems > New System Build > Ideas for a three monitor system build
Forum Homebuilt Systems : New System Build - Ideas for a three monitor system build
I think i want to build a triple monitor system for gaming, does anybody know what is needed in a new system to run three monitors well? if anybody has a good system build for one?
Thanks
Bobby
Sponsored Links
I've tried two and three video cards and I couldn't get them to work right together. I bought the Matrox Triple Head to Go Digital and everything works as I had wished. Makes it so much easier to use the three monitors together. Good for racing sims but a little hard to keep all that real estate covered in a first person shooter.
Reply to taso11
how much for a setup like that? +2 monitors i would think $1000 easy..?
Reply to doormatderek
- 0 +
The Triple Head To Go is $300. I'm running triple sli, 3 x 8800gtx, but I think that's overkill. I just wanted to try it ;) Matrox website should give you more information about video card requirements and what surround (wide) resolutions to expect. then get three identical monitors or at least monitors with the same native resolution. I had tried all other ways but never got it to work right until I got the triple head to go.
Reply to taso11
There are 1029 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
