4670 problem
Forum Graphic & Displays : ATI - 4670 problem
Hi, sometimes when i play a game my monitor says it has no signal but i can still hear the game still running through the speakers.
I have a Sapphire Ultimate 4670 512mb, Thermaltake TR2 RX 500 PSU, Dell 2209wa monitor, 1tb hdd and 500gb hdd, 1 optical drive, 2gb ddr2 ram and athlon 64 x2 4200. I realize this isn't the most powerful system but should be more than enough for Age of empires 3 and The Sims 3(at least i hope)
I have just updated the ATI drivers to 9.6 tried with driver only and with full CCC but the problem remains unchanged.
My case is getting plenty of airflow and temps are good.
Using Windows XP 32bit sp3 genuine fully updated.
This has been happening for months and have not been able to fix it.
Does anyone have any ideas, any help would be appreciated
part of me is thinking this is a PSU problem but i don't want to spend money on one if it's not
Sponsored Links
I don't think it will be a PSU problem, 500W is more than enough to power your system. I'm guessing its either a problem with your graphics card or monitor.
Reply to Hammeh
Thank you for replying
i have just recently tried Sims 3 again this time in windowed mode at 1024x768 and it ran good for over an hour until it lost signal and i had to restart, would this imply it's a problem with the graphics card?
Reply to chris19992
it's your monitor problem,you should change your monitor.i had this problem with my 15" crt monitor because my monitor doesn't support refresh rate above 60hz if i change resolution above 800*600
Message edited by TokY BlaY on 06-17-2009 at 01:00:54 AM
Reply to TokY BlaY
chek your vga temp maybe it's too high. i think ultimate is passive cooling version(i'm not sure) try to add a 90 mm fan on your vga heatsink
Reply to shayan08
I ran GPU-Z while playing and here is a minutes worth of readings until it went
photo here http://img35.imageshack.us/img35/2857/tempg.jpg
strange stuff at the bottom, hopefully it will shed more light on the cause
Edit: yes it is a passive card, why it shows fan speed i have no idea.
also this time when i had to restart the color quality changed itself to 16bit instead of 32bit
Message edited by chris19992 on 06-17-2009 at 04:10:21 PM
Reply to chris19992
hi chris19992 was having the same problem as you with the monitor also had bsod lots of times i think i have solved my problem by underclocking the card with rivatuner 701.5 core and 922.5 memory been very stable for two weeks now and i've rekindled my love affair with cod4 hope it helps darren
Reply to doobiduck
one more thing mate i'm using ati 9.3 driver only not the ccc thing
Reply to doobiduck
Tom's Hardware > Forum > Graphic & Displays > ATI > 4670 problem
There are 1329 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
