Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > X31 Freezes when Running On Battery
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - X31 Freezes when Running On Battery
The X31 freezes after about 2 minutes when running on battery. I have tried another battery and this did not resolve the problem
The machine starts up ok but then locks and there is no way to turn it off.
Sponsored Links
You may want to go into the power settings in windows and check how the systems is set up to operate when it is running on the battery.
------------------------------ http://valid.canardpc.com/cache/banner/490986.png
http://valid.canardpc.com/cache/banner/305006.png
Reply to shabaa
I checkd the power options in control panel and that is fine for battery...or are you referring to somewhere else to check t power settings ?...If so where is this
thanks
Reply to zignet
There are 1176 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
