Msi motherboard formatting problem
Hello,
pls help me m using msi 145 processor and ati graphics .. bt when i try to install a fresh copy of winxp..it initiates smoothly but then after checking my system hardware.. my system get restart several times..
finally no installation is done... plz help
1 answer Last reply
More about motherboard formatting problem
  1. Disable the auto restart (F8 menu) , to see the error.
    How are you trying to format?
    At the windows setup screen?
    Try by recovery console(cmd), using commands:
    format your_drive_letter:\ /q
    If it IS your hardware, see in bios if you have something listed as unknown or that isn't detected.
    U may eventually need to stick your nose (and screw driver ;) ) inside your PC. :hello:
Formatting Problem Motherboards Windows XP MSI-Microstar
