Tom's Hardware > Forum > CPU & Components > CPUs > What is the most power CPU that my GA-X38T-DQ6 LGA 775 will run?
Forum CPU & Components : CPUs - What is the most power CPU that my GA-X38T-DQ6 LGA 775 will run?
Just as the title states please. I have a Over clocked Core 2 Quad core processor running at 3.2 GHZ, some nice DDR3, an 8800 GT yadda yadda, I've had this for about a year and a half now somewhere therebouts.
The computer is fine, but I'm looking to eliminate the hiccups in my higher end games so I can run them at 60fps. I don't play anything higher than 1280x1024, so I'm not sure if I have a video card issue, or more so the cpu?
I'd like to continue running my XP Pro so I'd prefer to forget about 64bit.
Sponsored Links
Are you asking how high you can overclock a chip? Or how much power to give it? Or what is the fastest chip you can put in the board?
8800gt is kinda old. A 4850 is around $100...I would look into that.
Reply to festerovic
Yes, the 880GT is a bit old. At 3.2GHz, maybe a GTX285 (16,462) or HD4890 (17,255)?
The HD4850 is a little bit better, but certainly a more modern replacement for the 8800GT. Tom's 3DMark06 benchmarks show the following:
8800GT 11,109
HD4850 11,749
My own benchmarks PII X4 940 @ 3.5GHz indicate 13,208 for a single HD4850 and 18,494 for Crossfire.
If your 8800GT went belly-up today (ie died) then the HD4850 would be a good replacement.
Reply to seabreeze
Actually, I was really trying to figure out where my graphic bottleneck lies.
I wanted to know what the fastest CPU that would work my my MOBO. If you happen to know what the best video card for me is, I would be happy to entertain it as well. Overclocking is good, but I usually don't like to go more than 25%, so I just wanted to know what the best CPU out there is for an LGA775, thank you in advance.
Reply to Nettik
that cpu is a beast, get an hd4890
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
Nettik,
The fastest socket 775 chip that I could find available right now was the Q9650
http://www.newegg.com/Product/Prod [...] -%20%24400
Reply to festerovic
your current cpu is fine. there should be no cpu bottleneck.. you need to get at least 2 good video cards to have a cpu bottleneck for 90% of games.
Reply to rand_79
Fastest CPU for LGA775 is Intel's Core 2 Extreme QX9770 running at 3.20Ghz. With some overclocking it will reach a speed of 4.3Ghz
Message edited by yowanvista on 10-29-2009 at 08:04:28 PM
Reply to yowanvista
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
