Hey guys, i'm trying to figure out if something like this exists. I'm a huge fan of zip ties for *normal* case tidying. What i would like to know if there is something that has a sticky back end, that i could for example attach to an interior wall of a case, which would have a loop through which i could pull a zip tie, which i can then zip tie around cables to essentially pull them up against the case wall, rather than essentially floating in their own space.
------------------------------"The surest way to corrupt a youth is to instruct him to hold in higher esteem those who think alike than those who think differently."
Yes. I forget what they are called, or where you can buy them. You can also drill holes the the case, but that's a lot of work. You need to assemble the computer, plot where you are going to drill the holes, and disassemble everything before you drill.
Well, looks like i may have found something. Initially i was getting worried because places were wanting you to order a minimum of 100 and it was like $130 etc.
I found these, seems to be pretty reasonable, about $0.35/ea. Website had decent reseller ratings.
Anybody know of any place cheaper or better known etc to pick up something like this?
Reply to kutark
I am not sure why you would get a sticky backed loop and then ziptie the cables to said loop. If you check at your local hardware store, you should be able to find sticky-backed, openable looped fasteners. It's just a plastic fastener that you can slide open and shut, and you could route your cabling through there. That should do the trick. I'll also look around on the net for a link to said fastener.
EDIT: Yeah, that above link would work too. Not what I was talking about but that would still be pretty neat.
Message edited by roadrunner343 on 09-02-2009 at 07:40:02 AM
Awesome ragsters, exactly the kinda info i was lookin for :-). Not to suggest any of the other responses weren't useful. I was hoping for a site that kind of catered to the modder crowd, there were some other things i was hoping i might find, or didnt even know existed, but would be useful, like the 3pin fan y splitter. Can't tell you how much i would of loved those in the past, instead of using freakin molex adapters.
Reply to kutark
