How to solve onboard sound card problems solutions
Hello,
imy intel 845gvsr i using onboard sound on i format the system after that the sound card was not detecting and even showing the which was i found in c:\> alc notepad file check the os version and itried so many ways but not succeed please give the solution
1 answer Last reply
More about solve onboard sound card problems solutions
  1. Have you installed all the drivers for VGA, LAN & sound etc..
    If not installed download & install the drivers for your motherboard from here..
    http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR&OSVersion=Windows+XP+Professional*
    Your onboard audio is realtek.. so you can download the latest driver from here also
    http://www.realtek.com/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
    Hope this helps..
Drivers Sound Cards Windows XP
