I HAVE 2X2GB DYNET DDR2 RAM. BUT PC UTILIZES ONLY 3.12GB ONLY. CAN ANYONE TELL ME WHAT'S WRONG? THE MEMORY TIMINGS ARE 6-6-6-18 CR2 N THE DRAM:FSB RATIO IS 12:6 AND MEMORY CLOCK IS AROUND 400Mhz. please help.......
Which OS are you running? It appears that you are running a 32-bit OS and as such this only allows for 3.25 GB's of RAM to be addressed....you will need a 64-bit OS before all of your RAM can be addressed...All of your settings are fine BTW
u r right. i'm using windows7 ultimate 32-bit. thanks 4 the reply. nd the settings r right as u say then its good 4 me becoz i was tensed about y my ram is such low
