Power Comsumption Questions! ! !
Hi
Does a 850W PSU work at 850W all the time even my system only consumes about 420W? I would like to get a Corsair HX850 850W PSU which has amazing efficiency at about 425W.
http://www.corsair.com/products/hx850/hx850-efficiency-chart.gif
3 answers Last reply
More about power comsumption questions
  1. The answer to your question is no. An 850 watt power supply does not operate at 850 watts all the time. A power supply will only draw the power at the electrical wall outlet that is needed to operate the computer system.
  2. Cheers mate!
  3. If you expect to operate using only 425w max, or even up to 500w, I suggest you also consider the Corsair HX 620 which also has excellent efficiency at that level. I don't know where you are planning to buy the HX850 and at what price, but right now newegg is selling the HX 620 for $110 less than the HX850. Note that the listing says the 72 hour sale ends on 9/5. You might calculate how many years of operation it would take to pay back the difference.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Power Supplies Power Corsair Components Product
