Greetings to all. New guy here. Hoping anyone can help me out on this one.
I am putting together a pc for my son. But it wont post or boot at all. It's not even giving a beeping sound to at least tell me something.
Here's the bare spec:
Asrock 775v88 board - REFURBISHED
CPU - LGA775 for Intel® Pentium 4/Celeron processor
- FSB 800/533 MHz
- Support advanced Intel® EM64T CPU
- Supports Hyper-Threading Technology
- Intel® 04B/04A processors compatible
Chipset
- Northbridge: VIA® PT880
- Southbridge: VIA® 8237
Memory
- Dual Channel DDR memory technology
- Supports DDR400/333/266 non-ECC, un-buffered memory
- DIMM slots: 4
- Max. capacity of system memory: 4GB
Pentium 4 with 3.4GHz Processor socket SL7Z7 3.4GHZ/2M/800 - USED
4x1GB LOW DENSITY PC2700 333MHZ DDR 333FSB MEMORY (GENERIC BRAND) NEW
Planning to use this graphics card: http://www.matrox.com/graphics/en/pr...g_series/g450/
I read somewhere that it could be the PSU, I am using an old pc case and it has only a 250watt PSU, would that be a problem. Need to check first before I get I higher PSU wattage. And if it is the PSU, how much should I get, Thanks in advance guys, really appreciate any help.
- FSB 800/533 MHz
Chipset
Memory
- DIMM slots: 4
