Power SUpply Question
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power SUpply Question
I have a system that I built a couple of years ago that the power supply (Pc Power & Cooling 510-SLI) has died on it for the third time and I'm looking for a reccomendation to replace it:
As I said the one that keeps dying is a PC Power & Cooling 510-SLI and I'm looking for something that is similar but a little more powerfull for $100 or less. it'a absic systme with a Asus M2-N32-Sli Deluxe Motherboard a 2 sata Ii Hard Rives and a evga SLI ready video card. Any and all reccomendations will be greatly appreciated!
I have an account on Newegg and plan on buying the PSU there, unless someone has a better place in mind?
Thanks again
Sponsored Links
3 times ? That's the unit that PCP&C built thier reputation on, I'd probably be looking to find what caused it so that I wouldn't have to worry about losing another psu.
You can get more power,less noise, higher efficiency and just as good quality for $100 or less nowadays
http://www.newegg.com/Product/Prod [...] 6817371025
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
- 0 +
I just think that I've been unlucky? I don't do anything that great with the system, all I do is play some stand alone and mostly online MMO's like SWG etc...
Thanks for the reccomendation I think I'll go with that one? Unless someone else has one or two that they feel would work for me? The lower the price without sparing quality the better!
Reply to alazeer
These PCP&C PSUs have a 7 year warranty.
Reply to Twoboxer
- 0 +
That's one of the best choices, balancing price against the quality of the PSU.
It's kind of overkill, though, but clearly something has killed several good PSU's.
Reply to jsc
- 0 +
That's an excellent PSU. If my secondary rig needed a bigger PSU, that's probably the one I'd get, or maybe its 550W smaller brother.
Edit: Hmmm, right now they're the same price, so I'd get the bigger one.
Message edited by jtt283 on 09-04-2009 at 05:45:48 PM
Reply to jtt283
Just for some safety reasons can u check ur main power connection or the socket before u plug in with the new psu? becoz my friend bought 3 psu's from different company (not really good one but medicore he is running pentium-4, 512mb ram and 6200LE) but all the 3 psu's has been blown away. It was becoz of faulty socket of the main power connection. So check it out if the voltage and all other things are ok. But anyways if u buy good psu's like antec or corsair they have a very good safety system so even if ur psu blow up ur components will be intact. :)
Reply to redwine01
Again I'd say your PCP&C PSUs are warranteed for 7 years. Replace it. And by the way asking them how three of them could have "blown" might get you some answers.
I'm sure they'd be curious.
Reply to Twoboxer
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power SUpply Question
There are 1126 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
