GPU problems
When I play wow (world of warcraft) i can play at max settings just fine most of them time, but if i do a 10 or 25 man raid my vid card gets pretty bad so i usually put it to low settings...where it can still get pretty laggy.
i just want to find a way to know if its my vid card thats making it slow, my ram, my cpu, my hd, etc.
gpu: hd 4670 (oc'd a bit)
cpu: x2 5000+
ram: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
hd: some really old ide seagate barricuda
psu: antec 500w
and I was wondering if anyone has any experience with WoW and gpu's, im looking for a nice one that can handle 25 mans at MAX settings. I like ati/amd also.
10 answers Last reply
More about problems
  1. you overclocked the card?
    I would put it back to stock again (after checking its not heat related)
    when its not oc'd it pretty much does the same thing
    have 2 profiles, default is stock, then random one is oc'd a little...but its safely oc'd to what ati reccomended.
  3. hows the temputres look ? and what do you mean by bad, does it pixellate, slow performace etc?
    cant tell you about the temperatures right now, but while in a big fight with alot of stuff going on the fps just goes REALLY low, like not even 1 frame per second sometimes. No pixelation, none of that the fps is just super low. If I look away from that stuff then its fine.
  5. strange, and it goes like this over time <20 minutes or so, I would say reduce the image quilty abit to let off the stress off the card, but it sounds like its a little unhappy with temps or its overclock for whatever reason, that does happen sometimes.
    I did a OCerclock on my HD4870 and it pixelated overtime on farcry2
    it only does it when im looking at something really graphic intensive, if im not it goes right back to normal.
    im almost positive its not the temperatures, and its a 4670 so its not as good as a 4870.
  7. in a MMO, a lot of things can cause lag and raids/arenas are notorious for causing it. try turning down shadows and draw distance. I'm sure you are using vent in raids which does not help.
    You can always upgrade to a 4830/4850. Either one would will work well with WoW and your CPU.
    when i do raids i turn down my graphics settings all the way to the lowest of the low.
    was looking at 4890's and gtx 260's
  9. are you using a wireless connection? I was able to raid with a 7600GT and athlon x 4200 way back when on max settings. I know shadows have created more graphic work but you should not be having those kind of issues.
    your current PC will bottleneck the 4890, you would see little difference between that card and a 4870.
    Yes im on a wireless connection but usually 180-400ms latency
    and i was thinking about upgrading alot of my system
Graphics Cards GPUs World Of Warcraft HD Graphics
