msconfig problem!!!
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
When I type in msconfig I get an immediate error message
of Windows cannot find MSCONFIG. i use this feature often
and this just happen to me today for the first time. It's
just like MSCONFIG disappeared. Can someone help me out
with my problem???
Jurassic
6 answers Last reply
More about msconfig problem
  1. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    > with my problem???
    Some malware will prevent msconfig, regedit and other diagnostic tools
    from being used to remove the malware. Get a spyware scanner and go to
    work. If that isn't it, then you need to "expand" msconfig.exe from your
    XP source, either the \i386 folder or your CD.
    Kent W. England, Microsoft MVP for Windows Security
  2. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    diagnostic tools
    scanner and go to
    I ran Spy-bot and it found some malware and deleted it.
    Went searchign for the msconfig.exe file in the i386 file
    and it's not there. Still having the same problem.
    help.....
  3. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    It's a compressed file (MSCONFIG.EX_ ) in the CD. Open Command Prompt window and type:
    Expand X:\i386\MSCONFIG.EX_ -r C:\Windows\PCHealth\Helpctr\Binaries
    (Where X:\ is the CD-ROM drive letter)
    If MSCONFIG.EXE is extracted and still the problem persist, run a full system scan with an anti-virus software. (keep it updated).
    [The following viruses delete Regedit.exe, Regedt32.exe, Msconfig.exe, Taskmgr.exe]
    W32.Petch.B:
    http://www.symantec.com/avcenter/venc/data/w32.petch.b.html
    W32.HLLW.Maax.B@mm:
    http://securityresponse.symantec.com/avcenter/venc/data/w32.hllw.maax.b@mm.html
    Ramesh - Microsoft MVP
    Windows XP Shell/User
    http://www.mvps.org/sramesh2k
    AumHa VSOP: http://www.aumha.org
    <anonymous@discussions.microsoft.com> wrote in message news:1fd2e01c45824$6c4bcb30$a001280a@phx.gbl...
    diagnostic tools
    scanner and go to
    help.....
  4. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    After he gets the OS file restored, he and you and everybody else using XP
    should go to Doug Knox's site and create and keep a copy of those OS
    utilities which malware tends to disable. Those are: Task Manager, System
    Configuration Utility [msconfig], and the Registry Editor [regedit]. Get his
    setup file from here: http://www.dougknox.com/xp/utils/index.html
    Gene K
    "Ramesh [MVP]" <ramesh@nojunkmails.com@mvps.org> wrote in message
    news:Oh7mAGDWEHA.2928@tk2msftngp13.phx.gbl...
    and type:
    Taskmgr.exe]
    W32.Petch.B:
    W32.HLLW.Maax.B@mm:
    diagnostic tools
    scanner and go to
    help.....
  5. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    anonymous@discussions.microsoft.com wrote:
    > I ran Spy-bot and it found some malware and deleted it. Went
    > searchign for the msconfig.exe file in the i386 file and it's not
    You won't find it in the i386 folder, it's renamed and compressed. Use
    expand.exe to "extract" it from there. Use the command prompt window.
  6. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    That's a good idea Gene. Basically, the idea is to rename these utilities and run them, as malware disables these utilities based on the Process Name.
    "Gene K" <genekRE@MOVEolivianc.net> wrote in message news:exWonOGWEHA.556@tk2msftngp13.phx.gbl...
    Gene K
    and type:
    Taskmgr.exe]
    W32.Petch.B:
    W32.HLLW.Maax.B@mm:
    diagnostic tools
    scanner and go to
    help.....
Configuration Microsoft Msconfig Error Message Windows XP
