Tom's Hardware > Forum > Graphic & Displays > Nvidia > GTX295 problem with Crysis
ok i have built my new desktop few days ago and i installed Crysis
when i tried to play it it was very choppy and laggy. like it was unplayable
so i googled some forums and fixed few things in nVidia Control Panel.
and i have played Crysis again and it gives me average 10~20 fps. i have no idea what the problem is. the driver is up to date
i have updated today which is 6/19/09
today i have RMA'd my GPU for replacement thought it was defective. BUT! it's for replacement the other one will be here
and i just want to make sure if im doing anything wrong.
and here's my desktop specs
(Windows Xp SP3 32bits, Personally hates Vista)
(DirectX10 Installed)
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
G.SKILL 4GB (2 x 2GB)
ASUS M4A79 Deluxe Motherboard
XCLIO GREATPOWER X14S8P4 850W
ASUS ENGTX295
Please Please give me solution for this
SORRY IF MY ENGLISH WAS BAD TO READ IM NOT AN NATIVE SPEAKER.
Sponsored Links
Quote :
LOL at this bit.
Anyway, you forgot settings and resolution you play at.
I ain't sure about nvidia equipment but make sure you are running sli and if you run in 2d clocks while windowed make sure it is full screen.
Oh and did I mention lol at the first part I quoted.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
I dont get it why ppl RMA there products so quick. Since i doubt its the card.
Try running that card with a p4.. and youl get crappy results aswell. What i'm trying to say is we need your specs. And at what settings your playing it
Reply to ill b ben
I think so you try install Windows Vista and it works good and it always helps low some programs and it's can give you will glad for Windows with Games :)
Reply to Anonymous
I recall vista giving the 3870X2 a great performance jump back in the day, or it might have just been the upgrade to sp1, whichever... it may be the same case for that GTX 295, or any dual gpu card. But the settings and resolution you have the game at could be the problem... yes... there are possible settings that will give you 10-20 fps with a gtx295.
I don't see what the big deal is about vista, over time the majority of problems have been fixed, it is a very nice os to work with now... and xp could very well be your problem.
Reply to kevin1212
There are 406 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
