Hello again people of tom's hardware. I have a question about my current overclock, bear with me since im quite new at overclocking.
The issue is when I boot my computer up in the morning, sometimes it will freeze. It's happened on the first screen, while loading windows and one time screen just turned black.
The Overclock:
i7-930 2,8GHz OC ~3,5GHz with 1,125 vCore, and with turbo-mode, speed step and pretty much all stock settings left to auto except LLC which is Enabled.
Memory Corsair Dominator 1600MHz running at 1604MHz with DRAM voltage at 1,64v and QPI left on auto and timings on 8-8-8-24.
I've run Prime for about 6-7hrs straight, and then probably another 6 in shorter sessions with no errors. One core failed when i ran it on 1,1125v but then i increased it and got no errors after that. I've also done a memtest with memtest86+ with no issues.
Right now i've turned the computer back to stock settings and i've not had this issue since, however it's only been 2 days so im not 100% its gone.
So, Im wondering whats wrong with my OC if I get this issue only on startup and not during load? Do I have to increase vCore, QPI volt or is there something else that I have fudged up in my pathetic attempts to OC my computer?
/Kind regards Johan
The Overclock:
/Kind regards Johan
