Tom's Hardware > Forum > Graphic & Displays > ATI > Running integrated radeon X1250 and HD 4350 cards together?
Forum Graphic & Displays : ATI - Running integrated radeon X1250 and HD 4350 cards together?
I just added a HD 4350 and either I can run the integrated graphics or the card. In the bios I must check the start from the integrated or PCI to get one or the other to work. I have does as many combinations as I think of but nothing works. I have tried reinstalling the drivers of one while the other is running etc. In system the other graphics card is not listed at all. Catalysis does not help but what is interesting is that when I activate the 45350 card the DVI out is listed as 3, not as 1 when I use to ohboard. So at some level it seems to know it is there.
Vista ultmate 4G memory.
So before I add another card does anyone have any suggestions?
NH
Sponsored Links
You can't run integrated graphics and the card together, but you can use both ports on the video card and connect 2 monitors.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
You will probably have an issue with drivers. The 1k series is no longer supported with new drivers, so make sure you get some older ones.
Reply to Iarwain
I finally got both cards running. I installed the driver for the integrated card then put in the new card, changed the BIOS to start from the new card, installed the drivers, rebooted and then both cards work.
Reply to nothelix
There are 896 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
