Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > inspiron 8200 battery rebuild...
Forum Laptops & Notebooks : General Laptops & Notebooks - inspiron 8200 battery rebuild...
Archived from groups: comp.sys.laptops (More info?)
So I got a new battery for my Insprion 8200 after the old one decided to
last only about 5min, but it seems like it's a waste to just throw it away.
Is it worth rebuilding a battery as recent as that one?
- 2fast
Sponsored Links
Rebuilding Lithium Ion battery packs is both expensive and dangerous. It is
also very easy to build a pack with new cells, but still have it be
non-functional due to bad/failed elctronics in the pack.
We only rebuild Lithium Ion as a last resort. The battery for the Inspiron
8200 is readily available and fairly inexpensive. I sell it in Canada for
$149.00.
Jason Cawthorn
Technical Services
Ever Corporation (Canada) Ltd.
Mobile Computing Power Solutions
jcawthorn@evercorp.com
"2fast" <2fast@2fast.com> wrote in message
news:c5ctsu$mf7$1@news01.cit.cornell.edu...
away.
> - 2fast
Reply to Anonymous
- 0 +
> $149.00.
$149 is cheap? When you get the computer for a buck, it's prohibitive.
I've been able to find good surplus cells for a quarter each. Match 'em
for ESR, Spot weld
them together and they work fine...assuming you can figure out how to
reset the electronics.
Where can we find information on resetting the pack electronics.
I've been able to reverse engineer and reset packs where the processor
spec sheet is available. When it's a black blob like the Compaq 7770,
I'm in the dark.
mike
> Jason Cawthorn
> Technical Services
> away.
>>- 2fast
Return address is VALID.
Bunch of stuff For Sale and Wanted at the link below.
Toshiba & Compaq LiIon Batteries, Test Equipment
Honda CB-125S $800 in PDX
Yaesu FTV901R Transverter, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
Reply to Mike
Here's a likely contact for you - Pat Hoscoe - and the link to his
company's website. Give him the description of your battery, and he'll
tell ya whether you stand a chance of rebuilding it.
http://www.tnrtechnical.com/default.asp
If Pat says don't, I wouldn't push my luck. So ... good luck.
Reply to Anonymous
There are 437 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
