This will be my first build. I've done a lot of research and feel confident that the components are compatible for i7, sli and can be OC. However, since I've never built a system before, there may be things I'm not aware of, or there may be smarter choices in this build. I would greatly appreciate any advice or direction from those of you who have experience.
PURCHASE DATE: Approx. two weeks.
SYSTEM USE: GAMING ONLY
PARTS NOT REQUIRED. Display, keyboard, mouse, speakers and sound card.
PREFFERED WEB SITE: Newegg.com.
SLI: Down the road, yes.
OC: Maybe, only after I'm sure I know what I'm doing.
The i7 940 is a waste of money. I'd get an i7 920 along with the Xigmatek Dark Knight cooler and overclock the 920. I also wouldn't waste your money on a Velociraptor. The WD6401AALS is a very fast drive that will save you a ton of cash.
Thank you for the input guys. I've made some changes as a result of your suggestions...hard drive, ram and cooling. I'm still weighing the i7 920 suggestion. One can OC the 940.
One more thing, I'm unsure of and that's the operating system. Vista or XP? I've been using XP and have no issues. What would make me go to Vista?
Vista and XP allow for SLI, right?
The i7 920 and 940 both have the same overclocking ceiling. The 940 does nothing other than make your wallet lighter. A 32-bit OS can only address 4GB of RAM. The GPU RAM comes out of that total along with some reserved for the system, so you'd end up with less than 3GB available. I would use the 64-bit Windows 7 RC1 for now.
Thanks Shortstuff. I was aware of the ram recognition limit of the 32 bit system. I was not aware of the ceiling on the CPU's being the same. Good info. i7 920 it is then. Thank you again.
Message edited by gapper on 06-04-2009 at 09:22:18 PM
This will be one of my next purchases as well, i had already ran it on my pc for 28 days, then went back to XP Pro, i was sad not seeing all my memory i paid for...
Message edited by HavoCnMe on 06-04-2009 at 09:35:37 PM
I wouldn't waste your time with Vista Ultimate. That extra $75 hardly buys you anything useful. Here's a link that compares the different versions of Vista:
I, personally, would just use 64-bit Windows 7 for now.
Thanks for the info. I am thinking about Vista Home Premium OEM. $99.99
What would be the advantage to the RETAIL version? $259.95
I will upgrade to Windows 7 once it's released.
